Question about Pioneer DEH-P3500 CD Player
Wiring a radio
I have a pioneer deh-p3500 that I am trying to put where a pioneer keh-2929 was. The wires for the 2929 were labled and I matched them up with the wires for the 3500. Red to red, black to black, yellow to yellow... I get nothing. There is a yel/blk for cell use, there is a blu/wht for an amp use, and then there is this orange/white that says it is to hooked up to the lighting switch. The rest are speaker wires. I still get nothing.
Check the fuse in the back of stereo, also you have a main power and vcc which is acc make sure they are hooked up properly.
Posted on Jun 02, 2009
  • 15,935 Answers
Check auto fuse panel. Radio fuse may be out if you touched the 12V to ground while wiring.
bench test to verify proper radio operation before digging into your car.
Posted on Dec 22, 2008
Can I hook up a pioneer deh-p3500 without a harness?
If you are talking about the radio harness, probably not. If you are talking about the wiring harness to plug it into the vehicle. The answer isn't so simple. Aftermarket radios have standardized wiring colors. BUT, they don't match vehicle wiring. So, unless you know your vehicles wiring diagram very well, I wouldn't recommend installing without the wiring harness. If the problem is that someone installed in your vehicle before this and cut the vehicle side of the harness, then I recommend you visit scosche or PAC website to see if it is available. It CAN be done, the question is SHOULD it be done. And the answer is no. Harnesses are very cheap these days, unless you have a data transfer style radio, then it gets a little costly. Most are around $7-$20. Hope this helps
Aug 22, 2011 | Pioneer Car Audio & Video
Nee a wiring diagram for a Pioneer DEH-P3500 for a chevy s-10 pick up
1993 Chevrolet S10 Blazer Car Stereo Radio Wiring Diagram.
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Antenna Trigger Wire: Pink
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4? x 6? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
http://www.modifiedlife.com if thats not your year.They have all years all makes&models
Mar 06, 2011 | Pioneer DEH-P3500 CD Player
Need to wire it into dodge dakota
you will have to check with a radio dealer to get the correct "pigtail" to install that into your Dakota..and also the dealer can tell you if it is compatable with your Dakota..i hope this helps
Apr 26, 2009 | Pioneer DEH-3400 CD Player
Wiring problem
Here is the support page for the manula and the installation instructions. Solved?
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/CD-Players/DEH-P3500?tab=D
Dec 30, 2008 | Pioneer DEH-P3500 CD Player
What wire
yellow wire is constant 12V to retain settings. should be powered all the time.
Dec 17, 2008 | Pioneer DEH-P3500 CD Player
Wireing pioneer deh-p3500
Here is a wire diagram. I belive that is not a yellow with white stripe wire. I think it is a solid yellow wire that came off a pair of wires that is wher you get the white stripe.
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50148installation_manual_DEH-P3500_20021241433264130.pdf
Sorry that is all that I can think of the yellow wire. It does not show one in the wire diagrame. Good luck
Cuts on & off
how are your speakers-if the speakers are not in good condition or they cannot handle the power that your head unit puts out the radio will shut down to protect itself- also check your ground line to the radio if the ground is not clean the unit can show the same symptom
Mar 08, 2008 | Pioneer DEH-P3500 CD Player
DEH-P3500
pioneer keys. Long thin with a tiny barb at the end. You need keys, and remove the radio trim piece. Take to local shop and they can do it in 2 seconds.
Feb 17, 2008 | Pioneer DEH-P3500 CD Player
Remote wire
easy way to find out ..test light .one end into blue wire .other end onto earth turn deck on .if lights up yes ..just check that if you insert a disc or anything it does not shut down ..if it does it will not turn your amp on when play discs
Jan 22, 2008 | Pioneer DEH-P3500 CD Player
Wiring problem
Yellow/black
If you use a cellular telephone, connect it via the
Audio Mute lead on the cellular telephone. If not,
keep the Audio Mute lead free of any connections.
Orange/white
To lighting switch terminal.
Blue/white
To system control terminal of the power amp or
Auto-antenna relay control terminal (max. 300
mA 12 V DC).
Nov 30, 2007 | Pioneer DEH-P3500 CD Player
Pioneer DEH-P3500 CD Player Logo
285 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
