Question about Logitech QuickCam Communicate Deluxe Webcam
My microphone on my quickcam is not working it say its in use but its not
  • Logitech Master
  • 3,015 Answers
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Posted on Dec 03, 2010
SOURCE:
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
QuickCam mic doesn't work
I read another post that said to go to Logitech itself for up-dates. This I did......downloaded all new drivers, etc. (the disc that comes with the cam must be out of date !). Then when that was done, I went back on Skype and where you do a 'voice test' I was able to this time around to "choose" my webcam - this was not coming up before at all. So in doing that it activated the mic on the webcam and all was OK. We seniors are supposed to be savvy with the forever changing world of electronic devices today! (LOL)
Feb 12, 2009 | Logitech QuickCam Messenger Web Camera
Logitech QuickCam Express: Microphone not working
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Dec 08, 2008 | Logitech Quickcam Chat Webcam
Logitech quickcam
I had this problem on my laptop when I first got my quickcam. Go to the quickcam menu (should be a slim vertical bar). Click on the "gears" and then the microphone. At the top, it should offer a choice of microphones (maybe it says "quickcam" or "logitech" and "realtek"). You need to choose the "logitech" or "quickcam" option.
This fixed it for me, but it often switches back to the other one, so I frequently have to do this again...and sometimes restart everything once I do it.
Hope that works for you.
-Danimalist
Oct 09, 2008 | Logitech Quickcam Chat Webcam
QuickCam mic not working
Apr 06, 2008 | Logitech QuickCam Express Web Camera
If you have windows messenger follow below
Windows XP
Windows Messenger is a native Instant Messenger application to Windows XP. This application can be used to set the output device of your choice. In turn, this information will carry over to the MSN Messenger 7.5 application settings.
Launch Windows Messenger and execute the audio tuning wizard.
  1. Go to “Start”.
    Select “Run”.
    Type “msmsgs” and click “OK”.
  2. In theWindows Messenger, click “Tools” and select “Audio Tuning Wizard”.
  3. Follow the steps which are provided by the “Audio Tuning Wizard” and select your desired Microphone & Speaker device.
  4. Once this process is complete, close the Windows Messenger application.
    The configuration change made through Windows Messenger should now be set in the MSN Messenger 7.5 application.
Mar 08, 2008 | Logitech QuickCam Express Web Camera
Quickcam stx
Dec 10, 2007 | Logitech Quickcam Web Webcam
For XP users,try:
>Start
>ControlPanel
>Audio
>Sound Playback
Click on drop down menu arrow.
If there are two audio devices listed: Deselect current device; select second device.
>OK
Oct 05, 2007 | Logitech QuickCam Express Web Camera
The quick cam express and quickcam chats are the only two models built without a mic in the camera.
Oct 01, 2007 | Logitech QuickCam Express Web Camera
Logitech QuickCam Communicate Deluxe Webcam Logo
113 people viewed this question
Top Logitech Computers & Internet Experts
Damen Wong
Damen Wong
Alun Cox
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
