Why to Use a fuel with the lowest required octane in the car?
Low-octane "regular" gas is usually all that is required. Octane is only a rating of the fuel's resistance to engine-damaging pre-ignition ("knock") in high-performance engines (that few people have). Low octane gas is less expensive and a better value if that's all your engine requires. Best case scenario you're wasting money by filling up with a higher than recommended grade of gas. Worst case scenario that high octane fuel is building up damaging carbon deposits in your engine because it's not being burned as completely as lower octane fuel would be. Check your owner's manual to be sure. Modern high performance cars will sometimes recommend higher octane fuels because they are engineered to use those fuels. The use of lower than recommended octane will not make your car explode, the ECM (Engine Control Module, aka:computer) will adjust the fuel injectors and spark timing to save the engine and compensate for you cheaping out at the pump. Those adjustments will consist of retarding the spark (reducing power and efficiency) as well as dumping lots of extra fuel into the cylinders to cool them, potentially costing you more than getting mid grade or premium IF that's what your car requires.
NOTE: Remember that engines need less octane at higher altitudes. If your engine does not "knock" on regular, paying more for a higher octane rating is a waste since the increased octane makes no significant improvement to gas mileage and it is no better for your engine. All available fuels have detergent and additive packages.
This will help.good luck.
