Question about Samsung Televison & Video
Samsung tv S63B chassis
Blows strx6750 at switch on.
1990 chevrolet p30 motorhome chassis 454 engine automatic I replaced turn signal switch The horn works BUT it also blows when i use the turn signal
Since the horn wire is just a ground for the horn relay there must be a hole worn in the insulation of the horn wire and that is grounding to the chassis when you use the turn signal switch. no other explanation.
Jun 22, 2017 | Chevrolet Cars & Trucks
Str x6750
Check all the other components, at related SMPS circuit, for any loose solder terminals. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
May 09, 2014 | Samsung CW29M64NS 29" TV
Can not switch on TV Samsung CS-21Z57ML, when I change the fuse, it blows
Short circuited component/s at its min power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 01, 2014 | Televison & Video
Need to find the ceramic fuse for my samsung 50"
Hello Dyan, Hi you can find one at any electrical or electronics shop that sells spare parts, But mind you the reason why the fuse blows in the first place, have the power supply board checked for shorts such as a shorted switching regulator. If in the event the replacement fuse blows again, there is definitely a shorted part. Have this checked by a technician.
Feb 12, 2011 | Samsung FPT5084 50 in. Plasma HDTV
I have a small switching power supply in a cable
check around your diodes near the voltage regulation area for either a very bad diode or a direct short sometimes its near the resistor pack and very hard to see. But if it were me I would just change out the power supply and be done with it.
Sep 09, 2009 | Televison & Video
TV shuts off after 30 seconds.
Check chassis venting, sounds like thermal switch is tripping on top of light box.
Jun 25, 2009 | Samsung HLM507W 50" Rear Projection HDTV
How do I know if it is L6 or L3 chassis
you need to look on the right side of the set (facing the front of the set) for a small label that says
model code...
serial number..
if the version number is blank or PW01 you have the
L3 chassis.
if it says PU02 then you have the L620 chassis
also the L3 chassis has the ballast on a slight angle and the L620 has the ballast straight.
Dec 29, 2008 | Televison & Video
I have no brake lights, no hazzard lights, but the signal lights work. Wiring has no breaks, but the fuse blows as soon as the brake or hazzard lights are used.
there is a short somewhere-try disconnecting all components on that circuit,put new fuse and try using one,if the fuse still blows,problem is in wiring or switch unit,if not,plug one component in and a time until the fuse blow,replace component
accordingly.make sure there is no slightly shaved wire touching the chassis,this will show when all if d/c'ed and fuse still blows,good luck
Aug 12, 2008 | Chevrolet C3500 Cars & Trucks
Emerson TC1351 chassis power switch doesn?t work but remote power does. I have opened the set and used contact cleaner on the chassis switch but no change. Any ideas?
If that contact cleaner did not work, get a new switch and replace it.
Before replacing it just short both contacts where the switch is soldered, the TV should turn ON and OFF.
Good Luck.
Feb 17, 2008 | Emerson TC1351 13" TV
Televison & Video Logo
458 people viewed this question
Jerry Greenberg
Jerry Greenberg
