Question about GE JGBP40 Gas Kitchen Range
GE JGBP 40 Gas Range Ignitor Norton Style Glowbar Replacement
Damsel in Distress!
My oven won't heat. Burners and broiler work just fine. I belive that I need to replace the ignitor. I want to do it right the first time, so I've some questions.
1. My model number is JGBP 40 BEh1WH, serial number MF248995P, is the part number that I need EAP243425?
2. I would like to see a diagram of how the part is wired, where can I find one?
3. Is there a possibility that I've miss diagnosed the problem, and if so, what else should I consider?
Any and all help would be appreciated!
Thank you.
  • Anonymous Dec 27, 2008
    I have a slightly different model, but the same symptoms.
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
SOURCE: dacor erd36sbk/ng infrared ceramic broiler
Try doing a clean cycle for 4 hours to remove accumulated grease film from the ceramic surface. It worked for me
Posted on Jan 25, 2009
  • 8 Answers
SOURCE: Kenmore Oven Problem
the ignitor has to be on before the gas valve opens up and until the stove recognizes a flame, if it doesnt the gas will shut off and the ignitor will cool off, If you use the self clean setting to clean the oven you will destroy the ignitor much faster because they are only rated for about 1000 degreese for just a minute and self clean keeps it around 800 for an hour or so. You may just need to replace the ignitor.
Posted on Jul 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: Gas broiler won't light
Turn off the gas to the range. Place a amp meter on the wire between the ignitor and the broil gas valve. Turn the control to broil. If the amp draw is between 2.5 and 3.0 the gas valve is the problem. This is for round ignitors. If the ignitor is flat,the amp draw should be 2.8 to 3.7.
The control board is the least likely problem.
Posted on Sep 24, 2009
Testimonial: "Thanks much for the suggestion. I will try it tomorrow and hopefully we can broil again. Good job!"
I have a GE Profile XL 44 gas range, Model #JGBP79BEA2BB, Serial #RV224810P. The Broiler works, the oven does not. I am fairly certain the problem is the round style oven Igniter. I am trying to verif
What have you got to lose , 25.00-65.00 I would see if the ignitor works . Have someone else turn it on while you watch underneath if it sparks the try to get it closer to burner .
Jan 20, 2015 | GE Kitchen Ranges
I have a GE 44XL range. The burners all work fine and the broiler works fine, but the oven will not heat. Any idea what might be causing that?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 13, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE xl44 gas range broiler won't work,
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
Broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221257
Dec 26, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
On my gas kenmore oven, the oven first wouldn't get up to temperature, and now 3 months later it just doesn't heat at all. There is no gas smell or indication that there is a pilot light. My gas broiler...
Replace the glowbar ignitor in the oven. Turn off the gas supply. Remove the oven racks. Remove the base pan in the oven to access the ignitor. Most plug in. Some have wire nuts.
Your local appliance parts store will need the model number or the ignitor for a correct replacement.
Oct 31, 2009 | Kenmore Ovens
Broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | GE JGBP33 Gas Kitchen Range
Oven will not light. Ignition element will not even turn on
I have a magic chef gas range and the top of the stove burners work , the broiler works but not the oven..I think it is the glo bar. How the heck do I change this? It is a magic chef proven cooking performance from model # 8114p627-60 from about 1999
Jul 15, 2007 | GE EGR3000 Gas Kitchen Range
GE JGBP40 Gas Kitchen Range Logo
606 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
