Question about Compaq Presario M2000 Notebook
My notebook is overheating
What can i do to make it stop shutting off from overheating?
    Genius:
  • 2,028 Answers
Overheating is due to the fan not working properly. You need to check the fan connection and clean the fan. I've seen fans stop due to dust buildup, or even a hair wound in them. After cleaning, if the fan doesn't work properly and it's still overheating you will need to replace the fan. Keep in mind that overheating can cause serious and expensive problem, it needs to be fixed ASAP.
Posted on Jun 26, 2008
    Brigadier General:
  • 3,614 Answers
You need to buy a notebook cooling pad, if you don't have one on your laptop. this can help to reduce overheating of the laptop..
click HERE to see.
  • Compaq Master
  • 1,667 Answers
Very often the cooling is full of dust and then the fan can rotate but there is no air flow, sometimes it will be a lukewarm canister with compressed air, sometimes you can blow it out with your mouth in emergency situations, but the best is this with compressed air Make sure the fan is not twisted and the device is free of power.
Often the ventilation gates are closed by wrong ground, the capacitors do not like that
Posted on Apr 23, 2017
My hp pavilion dv9720us will run for about ten mins and then shut off
you can try to hover around the fan outlet the dust gathers and stops the cpu cooling down and then the cpu wiil shut down to protect the laptop from overheating if it runs longer but shuts down you will need to get in to the laptop and do the same around the heatsink fan and cpu
Jan 08, 2013 | HP Pavilion dv9000z Notebook
TOSHIBA Satellite A665-S6065 fan issues
The fan is probably going bad and will stop one day. Once the fan stops your computer will shut down due to overheating. Keep an eye on it.
Mar 29, 2012 | Toshiba Satellite A665S6065 Notebook
My acer laptop keeps closing down/ Any ideas or ways to resolve it
Laptops sometimes shut down to protect your hardware. If the fan has stopped working for example it may be overheating. Is the bottom of your laptop hot?
Jul 27, 2011 | Acer Aspire 5742Z-4200 Notebook
My Gateway computer shuts down ramdomly. This
Listen for fans coming on, as this sounds like overheating issue. If fans kick in and then stay constant or dont work at all.
The link is for Notebook hardware control, this will monitor the temp among other things (only reference as a guide any software can give you an indication but not exact temp) Generally if a laptop hits 90c it will auto cutout to stop major hardware failure normal running temp (40-55c upwards depending on use) http://www.pbus-167.com/
If the machine is overheating it could be due to blocked vents, faulty heatsink, fans not working or incorrect fitting and thermal paste.
In all honesty if this is due to overheat problems, as the machine has been cutting out my strong advice would be to do all the above ESPECIALLY re-apply thermal paste (arctic silver5) to cpu, it takes about 100-200 hours of use to start to work 100%.
hope this helps, let me know if i can be of further help
Nov 06, 2009 | Gateway T1623BU 14.1" Notebook PC PC...
My HP Pavillion DV100 notebook shuts down whenever it feels like. What could be causing this.It is 3 years old now so off warranty. It will work just fine for a little while and then voila! shut down.
Sounds like classic overheating, check your power supply fan, or the fan of your heat sync that seats over your CPU as well as the heat resistant insulation thermal lubricant that's there to keep it cool.
When fans starts to go the bears or motor starts to stick and will intermittently stop. When when it goes altogether it ceases to turn and can cause serious overheating damage to your circuitry.
Jul 27, 2009 | HP Pavilion dv1000 Notebook
Dell shut down automaticly can someone help
Sounds like the laptop is shutting down as a safety feature from overheating. Look to see if the fan is running underneath the laptop/notebook. It's possible that the fan is defective. If not, are you blocking the vents? Make sure this is room for air to circulate.
If it's not the overheating issue, do you have the power management system software set to hibernate? Maybe it is shutting down at the time interval set.
Hope this helps.
Dec 24, 2008 | Dell Inspiron 6000 Notebook
Shut off after 5 minutes
sounds like overheating. could be the heatsink on the cpu needs to be cleaned and re sat with new grease or a fan has stopped or is blocked. I would take apart the CPU housing and fan and check it all or take it to a local shop or send it to us www.qualit-uk.com/laptop-repair.htm
Sep 07, 2008 | HP Pavilion dv9000z Notebook
Compaq Presario M2000 Notebook Logo
1,591 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
