Question about SAMTRON 55V 15" CRT Monitor
Samsung v56 making tripping sound
Hey guys help me out pls m tired by solving this prob
m having samsung v56 CRT moniter,as soon as i start it makes tripping sound after 2-3min it starts n tat too it look round half screen only
  • jitendra singh
    jitendra singh May 11, 2010
    which half horizantal or vertical
  • 65 Answers
Check Vertical IC supply voltages +12v, -12v
and replace V. ic supply caps.
Posted on Oct 15, 2008
Describe your 105S51, 15 in. (White) 15" CRT Monitor Problem a blow line midle in moniter how to resolve the prob
Hey there.
I have recently written a tip on this problem. I suggest you give it a read and let me know how it goes.
You can see my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Enjoy my tip.
Slasher_X
Aug 25, 2011 | Philips 105S51 15" CRT Monitor
Makes a hard clicking sound in the passenger side tire area when i turn either way. ony when im sitting still and start to turn tho.
this sounds like a bad cv axle, this is what turns the wheels to make the car move if its clicking its going to break soon and leave you stuck out on the road, the axle needs replacing.
Sep 07, 2010 | 2000 Kia Sephia
Moniter display problem pls help me? single line in the moniter centre ?
If the line is horrizontal then the fault is in the vertical deflection circuit.
It is not worth repairing an old CRT monitor, unless you have electronic knowledge. I do not recommend repairing CRT monitors yourself, because there are dangerous high voltages inside these monitors, even though the unit is unplugged from the main outlet. The CRT tube will hold high voltages for weeks even though the monitor is turned off.
I suggest you put your money towards a LCD screen, they are inexpensive.
Aug 25, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
How to open back cover of samsung 55v moniter
Read somewhere that you need to insert a blunt screw driver in the slots between the cover and the the top of the front cover and press down lightly. hope this helps...
Feb 01, 2010 | SAMTRON 55V 15" CRT Monitor
Vibration and noise coming from front end.
Try this . Find an empty stretch of road . Accelerate teh vehicle to 30 mph ,while you switch the transmission INTO NEUTRAL, making sure there are no other vehicles in or behind your path. Listen and feel for your problem. Still feel it ? I would raise the vehicle in the air, and inspect ALL 4 TIRES for OUT OF ROUNDNESS. Cupping will not only cause a vibration, but also a noise. Hope this helps.
Apr 27, 2009 | 2001 Buick Century
Control lock meassage come out in the screen
Its aproblem of command section.Check its components one by one.you can identify this section (the front panal buttons goes in this section and a ic in big size and pasted horizantally in the circuit).if the components are ok then change command ic with new one.This will solve your problem
Sep 24, 2008 | SAMTRON 55V 15" CRT Monitor
Screen Shaking
make sure your pins on your mail connecter are 100% ok,then u
UPS of that system place far from the moniter .Insert VGA driver cd into drive and driver update via device manager and restart u r
system.In case ur graphics card damaged the moniter normaly
work as u describe.
Jul 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's "Klixon" overload. Call a commercial refer guy (not somebodys brother in law that works on A/C, it's NOT the same!)
Jul 15, 2008 | True GDM-26 Refrigerator
Samsung Monitor control lock problem
this problem is due to abad 7805 regulator ic ora memmory ic
Nov 22, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
790 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
