Question about Kenmore Microwave Ovens
Kenmore microwave #721-89941-1490
I was defrosting some beef and all of a sudden I lost power.The breaker is fine and there is power to the outlet.Is there a fuse in it that may have blown? mike
  • Anonymous Nov 06, 2008
    My Kenmore 721.8915081 stopped working alltogether and will not turn on at all.
  • Kenmore Master
  • 9,098 Answers
There is an internal fuse, plus one or two thermostats or thermal cutouts.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
My Kenmore elite microwave model 401.88523011 has lost power. The electrical outlet still has power to it. Is there an internal fuse or circuit breaker that may be causing the power outage?
Your microwave has an internal fuse. Usually 10 to 20 amp. You can pick some up at home depot or radio shack. Make sure you get the same amps and volts as the original fuse. Will be printed on your microwave some where usually. And if its one that is part of a double oven deal make sure that you check you're circuit breakers for the kitchen. Good luck.
Dec 16, 2014 | Kenmore Microwave Ovens
Microwave, kenmore 721.89822, will run when powered, but will not cook, no microwaves
HELLO.
Follow some straightforward troubleshooting steps to make your microwave work like new again.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks.
Sep 18, 2011 | Kenmore 80822 80823 80824 80829 1500...
I have a Goldstar Multiwave and have lost the manual. Can you defrost by time rather than weight such an a frozen breakfast sandwich?
You can defrost items by time but not with the Q-Defrost or Auto-Defrost functions. (I've found it best to defrost ground beef with timed intervals at power 1. Auto Defrost by weight usually starts cooking the meat. You will need to try it a few times to see how long and what power to use.)
Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/52491/GOLDSTAR-Countertop-Microwave-L1005548?brand_name_search=MA1011W . Sears Parts Direct may have a copy that you can order. (I didn't see it listed but didn't check the entire set of parts lists.)
I hope this helps.
Jul 10, 2011 | Goldstar MA-1011 Microwave Oven
How to defrost frozen ground beef with sharp carrossel microvawe oven?
The defrost instructions for ground beef are listed on page 15 of the owner's manual under the "Defrost Center" heading. If you do not have an owner's manual, here is a direct link to one that you can download or print for FREE:
http://www.managemylife.com/mmh/owner_manuals/71305/Sharp-Microwave-Oven-mic_man_R510H?brand_name_search=R-510
Remember to remove any thawed pieces of beef with each stage of defrosting for the best results. If you have any questions, please post back and let me know. I hope this helps you.
May 05, 2011 | Sharp R-510HW Microwave Oven
My Maytag MMV1153BA Over The Range Micro suddenly lost power.
problem is a blow fuse inside the microwave, you need to call a appliance repair tech
Jun 28, 2009 | Maytag MMV1153A Microwave Oven
Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
Feb 14, 2009 | Kenmore 62622 Microwave Oven
I can't figure out the defrost function on my microwave
There should be a lable just inside the door of the microwave telling you what keypad number to hit for poultry, beef and fish then you enter the weight. IE: Push defrost then 1 fpr beef then 2.0 for 2 lbs
Nov 27, 2008 | Microwave Ovens
Microwave Ovens Logo
706 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
