Question about Nintendo Wii Console
Lights on in the remotes, screens are up when you switch the tv on but there appears to be no signal from the remote to the console - ie no hand show to allow you to plat
  • foggymorning Dec 13, 2008
    the sensor bar is plugged in and in the proper position, in fact I bought a new cordless bar to see if that was the issue, and the hand still does not appear on the screen. also replaced batteries on sensor bar and remotes!
  • 62 Answers
Do you have the sensor bar plugged in and placed in the correct position?
Posted on Jun 27, 2008
Manual switch ok but remote not fundtion sharo tv
Be assured that fault does not lie with the remote handset itself. In that case repair or replace it.Remote control system has two parts. One is the remote hand set and the other lies within the TV or other device for which remote controller is being used. The hand set transmits commands in shape of singnals of particular frequency and pulses per second depending on the key pressed. The other part of the remote system lying within the TV receives, decodes and responds according to the commands received in shape of signals of particular frequency and pulses of paricular width and sequence. The remote controller uses invisible infra red light as the carrier of the signal. As the light moves in straight path, no obstacles should block straight line of sight path between the remote hand set (the transmitter) and IR sensor window (part of the receiver). Hence remove the blockage from the front side of the TV.Check if the IR sensor is not defective. Check if the associated circuit and components inside the TV are not defective.Check if the TV has any switch for selecting only manual mode and locking the remote mode.Hope, some sytematic exercise will bear the successful result.
Feb 19, 2012 | Sharp LC-32SB21U 32 in. LCD TV
Remotes dont work . The actual games work but no response from remotes[ ie no little hand appears on tv
Try to Resync the Wiimotes by 1. Powering on the Wii 2. Hold the red button on the back of wiimote (Under the battery cover) at the same time as you press the red button on your Wii (Under the from panel where the SD slot is).
Apr 02, 2010 | Nintendo Wii Console
The TV screen does not recognize that the hand held remotes are in use. Sometimes they jump around erratically so we can't play any games.
might just be that the senser may be in the wrong area, or you or you could be too close to the TV
Nov 16, 2009 | Nintendo Wii Console
The 'hand' on screen
Make sure that the Sensor Bar is setup correctly:
Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
Verify that the Wii Remote is being used between 3 and 8 feet directly in front of the TV, and that the Sensor Bar is placed properly (see Sensor Bar setup).
Verify that there are no bright light sources, including sunlight, behind or near the TV, shining towards the Wii Remote or reflecting off the TV screen. Also verify there are no heat sources (such as electric, propane or kerosene heaters, flames from fireplaces or candles, stoves, etc.). If there are bright lights shinning directly behind the TV or on the screen, turn the lights off.
If problem persist your Wii Remote need service.
Oct 21, 2009 | Nintendo Wii Console
Hand does not show up on menu
The main unit is not receiving the signal from the remote,
It can be a couple of things...
More than likely you have two remote handhelds. You may be using the wrong handheld to choose the options. Try the 2nd handheld.
Check to make sure the batteries are charged and handheld is ON
Make sure the receiver is in plain sight and not blocked
Aug 07, 2009 | Nintendo Wii Console
No connection from remote to screen
Your sensor bar is definitely burned out, you can get a new wireless one at wal-mart for $20. Often wii sensor bars burn out because people put it directly on the tv instead of using the stand, the tv gets hot and the LED lights in the sensor bar burn out. If you want make sure that it's the sensor bar that's broken, get a video camera and video tape the sensor bar while it's plugged in and the wii is on, if you can't see four LED lights on each side then it's broken.
Jun 14, 2009 | Nintendo Wii Console
Wii remote will not follow command.
It's problem a radio interference, since the wii controller uses radio frequences to contact the device, try to resync the wii controller.
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
Feb 09, 2009 | Nintendo Wii Console
Wii
(1)
Verify that the cable bar sensor is plugged into the back of the Wii console and that the sensor bar is properly aligned with the centre of your TV screen.
(2)
Check that the Wii remote is synchronized with the console using the POWER button on the remote control to turn on the Wii console. (The POWER button is the white button with the red symbol which is located in the upper left corner on the Wii remote.) If it does not work, try to synchronize the remote control, then turn the console and controls that respond correctly to commands.
(3)
Verify that the distance between the Wii remote and the TV display to be between 1 and 3 meters, that there are sources of intense light that can interfere with the proper functioning of the remote (read Guidelines game for Wii for more information ) And that the sensor bar is placed correctly (see Setting up the sensor bar). Avoid the presence of sources of infrared light as electric stoves, gas propane or kerosene, candles, fireplaces, stoves or other heat sources close to the console.
If the steps described above do not solve the problem, the sensor bar could have a problem. Read the following instructions:
On each side of the sensor bar are five infrared lights that located the position of the Wii remote. If these lights do not work, the cursor on the remote will not appear on the screen and you can not step through screens of settings. To see these lights, you must look on the LCD screen of a digital camera or a mobile phone. Verify that the sensor bar is connected and that the Wii console is turned on, and then framing the bar sensor so that it appears on LCD camera or cellphone. If you see five infrared lights on each side, the sensor bar works. Maybe you'll need to slightly adjust the position / tilt the camera or the telephone, but is rather easy to see these lights on the LCD screen
Jun 22, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
22 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
