Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub zero ice cubes are turning out badly
The service light is on - though the freezer and refrigerator parts are holding their temperature. The ice cubes are coming out smaller and whithered. There is no ice build up, no water anywhere. I did clean the pretty thick dust layer from the grate over the coils at the top of refrigerator - hadn't done that in 5 years.
  • Anonymous Aug 20, 2008
    small ice cubes very few Ice service light on
  • retsok Aug 30, 2008
    I have a 650 as well. My service and ice light is blinking and it has stopped making ice cubes. I tried your solution of hitting the alarm button for 10 seconds. Nothing happened other than turning the alarm on, which then started going off. How can I tell if my ice maker is on or not. I hit the on/off button and it makes noise- but I can't tell when it is actually on.
    Thanks.
  • 725 Answers
Hold in the alarm button for 10 sec and it will reset...let me know
Posted on Jul 08, 2008
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Nov 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub Zero ice cubes with black paint chips
HI, You will need to change the ice maker. You are getting the paint from then coating inside the cube tray.
Vic
May 17, 2009 | Sub-Zero Bottom Freezer Refrigerator
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
158 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
