Question about Sony PlayStation 2 (PS2) Console
The ps2 doesnt start
In my ps2 when i click on the red light it doesnt change. after opening it i saw that one square metal stuff was out and i cant figure out where to put it. after opening it i fixed one part and then when i clicked the button the colour changed to green.after puting the cover back i couldnt change the colour. please help me.
  • kstiteler Jun 28, 2008
    I took my cover off to clean the laser with air spray and/or q-tip. Problem is, i pulled out the cord that goes from the power button to the console. It's connected to the button (on the cover) but i dont know where the slot is to try to put the other end of the flat cord back in.
    Problem Solver:
  • 16 Answers
Try doing the following
if you'll check the disc tray side you'll see a white slot where the ribbonwire should connect you'll also find some connectors colored pink green and white if you'll look thoroughly it is located beside those connectors
Posted on Jun 30, 2008
Saw cuts bevel at 0 degree setting. Needs to set to about 3 degrees for square cut. Multiple saws with this problem. Is something bent, or worn out?
Check that the bed of the saw (the flat metal part on the bottom) isn't bent. I've had this sort of thing happen on a jigsaw that needed to be tapped back into square. Check the squareness of the saw with a framing square or a carpenter's square held against the blade and the bed of the saw with the blade guard open. Obviously, make sure the saw is unplugged before doing this.
Jul 28, 2011 | Makita Circular Saw - 15 Amp, 7 1/4in....
Gamestop Edge PS2 Wireless controller wont work. New batteries and the square control (router) box just keeps blinking green. I pressed the button for reconnect and it still does nothing I need...
If the light on the controller is flashing then the batteries are still good. There is a small reset button on the receiver that came with the controller. use a needle to reset it while it is still in the ps2. make sure that the ps2 is turned on and the green light is flashing on it. it should blink a few times and then the light on the controller should turn red. once it does then press start and your good to go.
Hope this helps!
Nov 08, 2009 | Gamestop Edge Wireless Controller for Xbox...
Opened up a PS2 and square metal piece fell out
If you look on the left hand side of the top plastic bit you will see what looks like 3 holes. You have to place metal bit to match up with the central hole but in the other half. The smaller side fits in a perfectly sized hole.
Aug 27, 2009 | Sony PlayStation 2 (PS2) Console
PS2 Metal square loose inside?
its nothing it goes on the inside on the left side its just there so you can buy a stand to stand your ps2 up
Jun 22, 2009 | Sony PlayStation 2 Slimline Console
My ps2 does'nt turn on when it's plugged on!!!!
Hey man, I had the same problem a few weeks ago, but not anymore! What's wrong is that a cable inside has become unattached, this cable controls the front buttons. What I did was open up the top of my PS2 and check the cable,(it should look like a strip of paper) if it is unattached then you have some work to do. Flip the Ps2 over and open the bottom up. You should see the motherboard and lots of other stuff. Ignore it. What you want is a small port on the side of the front buttons cleverly hidden under a metal box thingy. Plug the end of the cable in to the port. On my Ps2 it din not stay in, so I had the Ps2 on and wiggled the cable until both front lights light up. Then you need to fasten the cable down in the right position. I used Scotch tape, but you can use whatever you want, just as long as it holds it down IN A POSITION WHERE ALL LIGHTS LIGHT UP! If this does not work, then I got nothing, hope this helps! Here is a you tube video that might help!
Apr 27, 2009 | Sony PlayStation 2 (PS2) Console
Metal spacer inside ps2 slim
Maybe it is placed under the laser???????????
Jun 17, 2008 | Sony PlayStation 2 Slimline Console
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
Changing of ps2 consol light from green to red
try to hold the red button & see if it works. if not then turn the ps2 off & try again. if it doesnt work then look for a nearby ps2 repair shop. dont go reparing over 90 pounds when you can get a new one. hope for the best, eh. GOOD LUCK!!!!
Aug 18, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
