Question about Kenmore Oasis HE 27082 Top Load Washer
Kenomore elite washer
My washer has an LD error i clean the drain and replace a new water pump but still give me that dam message sorry fustrated can you please assist thank you
  • agurule2 Jun 27, 2008
    Man.... That was a piece of cake i appreciate the detailed instructions. There was a obstruction in the entrance on the drain. Thanks for all the help brotha now i dont have to smash my washer with a hammer no more.
  • 246 Answers
Drain problems can come from a number of places. If you've already replaced the pump, then let's first check The drain insdie your tub. If it's plugged from that side, you'll get the same problem. So with that said...Where the front panel and the top of the machine meet, there is a crack. When using a flashlight, you will see 4 items in this crack. 2 are green 2 are black. The black
pieces are support studs, ignore them. The green one's are clips that hold the top to the front. Using a putty knife (easier) or a small flat head screw driver (a bit more difficult) push one of the green clips towards the rear of the machine while lifting on the top (warning they are very stiff). You can wrap the tool in a light
cloth to help protect the finish, althought it may make the clips more difficult to remove. Only lift slightly (too far and it will bind on those support studs I told you about) Now press the clip on the other side and lift the top up.(now this is easier if you have a second person to hold up the lid while you work underneath.
You will see your tub from a new perspective. First you will see a plastic ring around the top of the tub. Disconnect the green clamp on the hose towards the left rear using a pair of pliers or channel locks. The ring is held down with clips all of the way around the tub. By pressing down over each clip and pulling the clips slightly forward, you can remove the top ring. The rest is the easiest part. In the center of the basket, there is a small cap. Remove this with a small flat head screwdriver. Remove the bolt (7/16") that is underneath the cap. Now lift the whole basket
out. If your small items get too far (ie, the pump), remove the back panel. On the left hand side you will see a small black hose towards the botom. This connects to the pump. Forign objects can lodge in here keeping it from draining also. If you
disconnect the hoses, have something handy for all of the water to go into (large wet vac is usually the best). Drop the 3 #20 torx screws and the pump will come down and you can remove the obstructions. Finnaly, try re-seating your drain hose. If it is too far down side the house drain pipe it can cause problems as well. Remove the drain hose (the thicker black hose from the back of the machine) out of the wall. Now re-insert it back in only 6" going into the drain. When they go in too far, the drain in your house that prevents odors from coming back out of your drain causes a siphon that pulls the water back out when the washer is filling. Make sure to tie the drain hose down with a tie so it does not pop back out when the washer is draining/ spinning.
Posted on Jun 27, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Kenmore elite oasis top load error code Ld
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Ld error code
Kevin
Oct 08, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Ld message
Hi
An LD error indicates long drain time which means that there is either something stuck/clogged in the pump or the pump itself has gone bad and should be replaced. You can take it apart completely and check for impeller damage or clogs. You have to clean it completely so make sure that you have lot of towels ready as there will be water coming out of it when you clean the pump. Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Washer is diplaying Ld and won't restart
Ld stands for long drain.
Here is what the manufacture says about that error, my comments will follow.
LONG DRAIN If the drain time exceeds eight minutes, Ld will be displayed, the water valves will turn off, and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be cleared and the machine will turn off after a maximum of eight minutes. Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the drain pump filter for foreign objects, and also make sure the hose from the tub to the pump is not plugged or kinked.
4. Check the electrical connections at the pump and make sure the pump is running.
5. Plug in2_bing.gif washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Phil's comments -----> This error is usually due to something getting stuck in the drain pump or drain hose, typically after washing a rug with a rubber backing that has come off or small articles like baby socks that were not put into a garment bag prior to washing.
To clean out the pump the machine would need disassembled and is best done by a service professional unless you are up for a good challenge.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer does not finish the drain cycle and it shows a LD error and does not finish washing.
LD error is for long drain. The pump filter in the pump assembly is probably clogged. Remove front lower panel, pump assembly is in the front with a cap that unscrews. Once cap is unscrewed you can slide out the filter and clean. Remove as much water as possible from basket before taking off pump cap or else water will come flooding out when filter is removed. Reinstall and run drain spin cycle. Should drain ok.
Feb 02, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
Ld code on any cycle
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
110 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
