Question about Whirlpool GEW9250 Electric Dryer
Thermostat & Fuse Wiring
Replaced the heating element - broken wire. Also replaced the thermostat and fuse. Not sure I got the wires in the correct position. Drying fine but clothes are extremely hot when the cycle is finished. Not sure the sensor is working?
Is the position of the wire on the thermostat and fuse important to regulating the heating element?
Thanks for your help?
  • 413 Answers
The heating element failure along with the symptoms you are now experiencing, may indicate blocked or restricted air flow through the exhaust. If airflow is poor, the heater will overheat and eventually fail.
Check the exhaust hose in the rear of the machine and make sure it it not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic. If everything in rear looks OK, check the outside vent hood for any blockages. If everything checks out, the exhaust system may need cleaning. Cleaning kits are available at most home improvement centers and at this web site: http://www.linteater.com/.
Posted on Jun 26, 2008
Bosch HBN7052 - main fuse tripping even after replacing the heating element
It appears there is too much current (electricity) being drawn towards the element, seeing once you replaced it, it worked fine for 5 minutes and then tripped again...I believe the problems lies within the wiring going towards the element, or the thermostat that controls the amount of current coming towards the element. Instead of turning off at a desired temperature, its not and continuing to heat up to the point of tripping the fuse. Try replacing the thermostat.
Dec 01, 2013 | Bosch Ovens
Kenmore dryer bought in 2004 stops heating
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
Nov 01, 2008 | Kenmore 64852 Electric Dryer
Dryer had built up lint,blew fuse,now will blow fuse after cleaning and replacing vent hose
if its heated electrically, not by gas,then it sounds like the heating element has shorted to the case and this would blow the breaker
Jul 28, 2010 | Amana NDE2335AY Electric Dryer
My dryer is no longer heating up and it does not time out, what parts would i need to fix the problems?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug
Whirlpool style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Oct 10, 2009 | Kenmore Dryers
I replace, heatng element, checked breaker,
there must either be a broken wire or burnt out wire or the control unit.
Sep 28, 2009 | Fisher and Paykel DEGX1 Electric Dryer
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 31, 2009 | Kenmore Dryers
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Not heating up
check the wiring to the heating element and ensure all the connections are tight and there are no burned wires. The heating element should be continious with no breaks.
ohms should peg the meter if everything is good.
Jun 02, 2009 | Dryers
Whirlpoool dryer not heating replaced the thermostat
Dont know the model number you have, but most of your items are located in the back of the unit. You need to make sure you replaced the thermostat, and not just the thermal fuse. The thermal fuse sits on top of the element shield, the thermostat is lower, down where the wires go into the element. You may have changed the thermal fuse, but the thermostat may be out. You will need to check (with an ohm meter) all the componants to find the trouble. If that thermal cut-off has went bad again, change the thermostat with it. Be sure you have very good ventilation all the way through, bad vents will cause problems like this all the time. Let me know if you need parts info. Let me know a model number as well.
Nov 16, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
251 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
