Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Cloudy screen/ i recently got this tv from a friend, we moved it to my house over the weekend. He says "it was working good before", but the picture is far from good, it looks cloudy. Such as there is a shadow of color, like a kid coloring outside the lines. The colors themselfs seem to be pretty good, its just a cloudy. I do not have the remote for the Tv either. Thanks for any advice, or can the buttons on the front get me to the menu, I haven't been able to check any of the settings. Or I have a universal remote if you know the code for the philips. Thanks again. Jason
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
More than Likely your Tubes are getting weak!, (3 tubes - Red, Blue, Green) Need Replacing or Rebuilding (fluid change). g.
Posted on Jul 01, 2008
Dark cloud thick lines appearing on my LCD TV
It sounds like a loose contact to your T-con panel. Before the problem happened, had you recently moved your TV? A picture would help my friend also if you have the model number.
Jun 17, 2013 | Televison & Video
I have a 42 inch spectroniq tv, i moved over the weekend, so i unplugged the tv and when i plugged it up at my new house, i just get the sound with a blank screen
I have a Spectronic LCD HD 42 "color screen is black with bright colors, sometimes does not look good, it lacks definition to see.
Oct 30, 2009 | Spectroniq PLTV-42HW68 42 in. LCD TV
I moved my tv to a friends house while i moved. we turned it on without leaving it get to room temp. think i blew a picture tube how do i detect this and how much is it to be replaced and also what parts...
picture tubes do not "blow" go bad by going dark check your circuit board for fuses test them and, replace the bad ones as your high voltage circuit is what lights up your tv tube... tv tubes do go bad when they do they show "blooming" and, bad ion masking not a black screen unless the tv is a newer lcd / plasma screen then just replace the inverter board or, cold cathode
Apr 26, 2009 | Televison & Video
Couldy image
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 14, 2009 | Philips 46PP9302 46" Rear Projection...
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Hi my picture is not as clear as my friend's tv. My screen seems almost cloudy.
It depends upon the room size and how you have placed the tv. if u position it in a proper manner then you will have a clear view.
Jan 01, 2009 | Sony BRAVIA KDL52XBR2 Television
Need to fix the color and screen
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
