Question about Bose Lifestyle 38 System
Bose Lifestyle 38 Optical Input Problem
My parents have a Bose Lifestyle 38 in which they never used the optical input. So I had them purchase an optical cord to input from cable box to TV to receive 5.1 audio. The problem is that it seems like some of the audio channels aren't present with the optical input, especially some commercials where no audio is present. I have also tried other output sources such as my XBOX360 and the same problem exists where certain channels aren't present. I have also tried 3 other optical cables which I have and they don't remedy the problem. Any tips would be much appreciated. Thanks!
  • 14 Answers
SOURCE: Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Posted on Dec 24, 2007
SOURCE: Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Posted on Feb 17, 2008
smarthome2
  • 1114 Answers
SOURCE: I am trying to figure out how to connect my blu
Only one can be digital. TV preferably since you probably watch more tv than dvds. use the analog output from the bluray to the analog in on the lifestyle 28 and optical for TV
Posted on May 17, 2009
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
How do I transfer music from my lifestyle 38 to a newer unit
Suggest you consult with BOSE
My inference from
https://worldwide.bose.com/productsupport/assets/pdf/guides/lifestyle/en/ig_en_ls18_series2_ls28_series2_ls38_series1_ls48_series1.pdf
26241829-avo1hezaf1vg34ez5fnknftc-5-0.png 1. You should be able to backup using the DATA Connect port.
Not sure of the pin configuration and external device.
2. You should be able to connect using Optical-Out port to Optical-In of new device (if it exist)
Jul 20, 2016 | Bose Lifestyle 38 System
Tip
Reset Bose LifeStyle 38 VChip Password
Bypass or Reset Bose LifeStyle 38 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 38 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 38 Manual Download
Bose LifeStyle 38 Video Mode
on May 02, 2010 | Bose Lifestyle 38 System
No sound using optical out on sony bravia xbr
Optical Output is not generally used for a subwoofer output, nor is it used as a subwoofer input. Please check the type of connection again to be sure. Both methods are for digital use, however, the Optical output uses an LED for digital communications at the receiver, as well as an Optical transistor to receive this input at the subwoofer. Optical connections willing have a blicking light at the end of the cable that goes to the subwoofer, coaxial(RCA) connections will not flash. For more information, please contact me at my website audioserviceclinic.com. Thank you.
Sep 23, 2013 | Bose Lifestyle 28 System
How to connect pc to bose lifestyle 38
Method 1 (easy): you'll need to get a 3.5mm to RCA audio cable pictured here: http://www.daydeal.com/files/images3/blk_rca_cable.jpg plug the 3.5mm end into the computer's speaker/headphone jack and the RCA (red&white) end into the lifestyle 38.
Method 2 (harder): You can purchase and install a PC sound card that has an optical out option and also an optical cable. Then you can use the lifestyle optical out jack. This is a digital connection so the sound quality is better and better suited for the 5.1 channel that the Lifestyle 38 has.
Mar 01, 2011 | Televison & Video
The volume control on my Bose 38 lifestyle system will not adjust the system, with either the remote or the volume controls on on the console.
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
Nov 28, 2009 | Bose Lifestyle 38 System
I have an optical cord plugged into my bose system but when i change it to aux it doesnt work
Using the remote control, and the on-screen settings menu, you must set OPTICAL as your AUX input. After this is done, Your Bose Lifestyle system will recognize the signal on the optical input.
Oct 19, 2009 | Bose Lifestyle 38 System
We want to hook up an HDMI dvd player to the tv and have the sound come thru the Bose Lifestyle 38 (older model, did not come w/the HDMI converter that the 48 has or newer systems come with). We are not...
The best way to do this is to take your OPTICAL AUDIO OUT from your TV - (if it's a newer TV) - plug it in to the OPTICAL AUDIO IN on your BOSE system, then use the 'TV' source on your Lifestyle 38 to get the sound from. I have sound for X-Box, DVD player, Blue-Ray Player and Wii being pushed through the TV back to the BOSE and it sounds great. I don't have to change the source on the BOSE very much either - except when I listen to stored music!
Sep 27, 2009 | Bose Lifestyle 38 System
Pretty much the same problem
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
Hope this helps.
MC
Jun 26, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
Connecting lifestyle 27/38 to psp3
Your Bose system doesn't lead sound trough hdmi.
You must connect the optical cable with your lifestyle.
Change the sound connectionsettings in the menu of your ps3.
You also need to assgn the optical connection in the setup menu of the lifesyle. e.g. optical=aux.
Dec 28, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 38 System Logo
1,202 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
