Question about Sylvania 6432GG 32" TV
Changing from cable to antenna
I disconnected my cable and am trying to change the tv back to antenna. I cannot figure out how to do this
Angel,
You need to get rabbit ears. Hope that helps.
Posted on Jun 30, 2008
Sharp Aquos 32 LCD freezes on air channel
I had the same problem, same channel, same day. It must be a problem with signal strength. With the TV on, I unplugged the coax cable that leads to my antenna (I am not on cable). As soon as I disconnected the antenna, I could change the channel off of 11.1. I plugged the antenna back in and all other channels work. Hope this helps.
Jan 27, 2013 | Sharp Aquos LC-32D42 TV
Bought a Soney KDL-46EX500 last week. Still tring to get it set up. Got the digital local stations programed into it today. (finally) Now I can not figure out how to switch back and forth from locals...
Looking at a diagram of the back of your TV I see that you have only one Coax input. You will need to plug either your antenna or the DirecTV in one of the other sources available on the back of the TV.
According to DirecTV's website, their box also uses composite video cables and depending on the age of that box, may have an HDMI connection also.
Looking at the back of your TV, the composite video cable input is the top two rows to the right of the Coax input you are currently using.
Once you have both connected to different inputs, you can use your remote to switch between the sources and watch whichever you like.
May 03, 2017 | Sony Televison & Video
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Sep 05, 2009 | Memorex MT2206 TV
Can not get my TV to go back to set-up menu
My husband tried to fix it and couldn't get it so I emailed you. I looked at it yesterday and found the screen I was looking for and was able to change it from antenna to cable. Thank You
Mar 30, 2009 | Vizio Televison & Video
A humming noise coming from tv when cable and ps3 are hooked up
I fixed mine by removing the cable wire from my tv. For some reason tv cable and the old PS3's cause a problem.
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
Toshiba 50h12-reception problem with ant 1 & 2
the tv has a built in decoder. if its scrambled it may be on the wrong setting. try resetting tv to factory settings and see if it sorts its self out. if not it may need the av board changing as it has a fault with the decoder chip.
May 23, 2017 | Toshiba 50H81 50" Rear Projection...
Cable/antenna
To change between cable and antenna on your TV,
Press Home to display the "XMB" menu.
pick "settings" on the menu
then pick "channel" on the next menu
under channel settings, select "on" for cable and "off" for antenna TV.
Your user manual is available for download and option printing at the following link :
http://129.33.22.12/release/KDL40XBR4.pdf
May 16, 2008 | Televison & Video
Sylvania 6432GG 32" TV Logo
377 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
