Question about Weber Genesis Silver A Grill
I replace the propane tank on my weber and it won't lite. Gas seems to be coming out of what I think is a regulator from a small hole as well as the burner
    Champion:
  • 254 Answers
If the small hole is connected to the gray device (regulator) you attach to your tank this is the vent and you should not be ablee to detect gas coming from it. If this is the case your regulator is bad.
Posted on Jul 01, 2008
Unable to get gas our of 'Blue Rhino" propane
The problem is an easy fix. Replace the current Hose/Regulator Assembly with a new one. They run about $30.00, at home centers and hardware stores that sell grills and accessories.
Once you install the new one and connect it to the gas tank, open the gas tank valve Very Very Slowly (Slow Motion, Slow) until it's fully open. If you don't do it this, the new regulator will lockup.
Hope this helps you & thanks for choosing FixYa.
Aug 25, 2011 | Weber Spirit? E-310 Propane Grill
Weber genesis S 320: Most BBQs have a hole in the side to run the propane line from the tank in the cart to the burner insert. The side panels on this seem to have no hole. Perhaps a small space right at...
Your correct. As looking at it, the right side panel has a hole just larger in Dia than the Regulator to fit thru. Feed it through to the inside of your cabinet and connect. There is also a Propane indicator that I haven't hooked up yet. Enjoy.
Aug 31, 2010 | Weber Genesis S-320 Propane Grill
I need to convert a weber nat. gas grill to propane and i can not find the kit, can you help?
OK - you may not like this answer, but it is what is is :^)
Its common to find kits that convert propane to natural gas (NG) but not the other way around. This is because NG has less energy per square foot than propane, therefore, the holes in your NG grill controls and burners will be bigger to move more gas and get the BTU's you need.
When you convert from propane to NG, you can simply drill the holes bigger and remove the regulator. But the reverse is not practical because you can't make the holes in a NG grill smaller without buying all new burners and control knobs. I guess that's the bottom line - your "kit" is simply to replace the burners and controls with propane-specific parts. You might be better off to just buy a new grill by the time you go through all that. If you have a Weber, their web site has all the manuals and part numbers you would need.
Keep in mind that propane tanks are under higher pressure and you MUST have a regulator. I've heard of some people that simply slap a regulator on their NG grill, but you will not get even burning or proper performance (again because the holes will be too big). In my opinion, it's simply not worth the danger to you or your family.
Aug 07, 2010 | Weber Genesis Silver B Grill
Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
May 17, 2010 | Weber Genesis Silver B Grill
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
Our grill does not lite. There is propane. Could it be the gas regulator?If so how do we test and fix it?
There are several possible problems, but I would start with the basics. I know this sounds silly, but is the gas at the tank turned on?
OK - assuming its not that easy, clean out the burner tubes to make sure spider webs or other obstructions are removed. Re-assemble and try again.
If it still doesn't lite, try manually lighting it with a lighter or match. If it lights fine that way, its likely your cross-over ignition and you can just replace it
Go to the Weber site and download your manual. It will have further trouble-shooting procedures, as well as the correct part numbers you will need for your grill. http://weber.com/help/manuals.aspx
May 20, 2009 | Weber Genesis Silver C Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Jul 18, 2008 | Weber Gas Go-Anywhere Grill
Weber Genesis Silver A Grill Logo
268 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
