Question about Dishwashers
I have to connect a 'Y' piece connector to my dishwasher as there is currently no cold water getting to it. How do i go about doing this?
If I'm not mistaken only hot water goes to the dishwasher. What you have is a valve with two outlets usually 1/4 or 3/8 one goes to supply side of sink faucet and other to the supply line of the dishwasher. This valve connects to the hot water supply line of the house. The stub outs should be close to the D/W. If you want to use cold water then you will have to connect this valve to the cold water supply and then connect one side to the dishwasher and the other to the the cold side of sink faucet. Also I believe that dishwashers need the water to be at a certain temperature +/- 150 degrees.
Home Depot/Lowes sell the valves fairly cheap. Hope this helps.
Posted on Jun 26, 2008
Can I just use a cold water feed for a Bosch precision WFG2420?
You can use just a cold feed, but both hoses need to be attached using a 'y' piece connector, the y piece is connected to the water tap and the both hoses are attached to that, then to the washing machine. I have added a link so you can see what a y connector is, if you don't already know.
http://www.amazon.co.uk/Washing-Machine-Dishwasher-Piece-Splitter/sim/B005AUMIZA/2
Feb 27, 2013 | Bosch Washing Machines
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
Do you connect to cold water or hot
You need to hook that to the hot water line...often the dishwasher will work better if you even run water to the sink and get the water hot before starting the dishwasher....they will keep the water hot but do not have a strong enough element to heat cold water hot enough to do a good job for you...
heatman101
Feb 02, 2011 | Dishwashers
Can wjs1265w be connected to hot and cold water supply using Y connector - or must it be cold fill ONLY?
If there is only 1 inlet connector at rear of washer, then you must connect to the cold supply.
All current washers and washer dryers are cold fill only now.
If it has 2 connectors, then you must still connect to cold using a Y piece to make the final connection to washer.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
Im instaling a 2 yr old zanussi aqua 1000,it has a hot and cold feed,there is just a cold feed at the house
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=213690&brand=&model=&part=y-piece&style=washerhelp
Washing machine is a hot and cold fill, but I only have a cold water supply You can use a Y Piece connector (external link 4Washerhelp spares) to connect the hot and cold fill hoses to a single cold water supply. The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may be able to buy this part also from a DIY store like B&Q)
Oct 21, 2009 | Washing Machines
AEH Favorit 50730 dishwasher seems to work fine other than the water never gets hot. Is it easy to replace the heating element or whatever that could be faulty?
If this dishwasher is a residential dishwasher the water that is supplied to the unit is from the hot water side of the sink supply. The dishwasher does not heat the water it uses water from the water heater that is connected to the house. It sounds as if the dishwasher is hooked up to the cold water supply instead of the hot water supply. The heating element you see in the dishwasher is for drying purposes and not for heating water. I would check the hot water supply for your dishwasher to see if that could be the problem. Also remember unless you have a recirculating pump on the hot water there will be an amount of water in the pipe from the water heater and the dishwasher that has sat and cooled down over a period of time therefore when you turn on the dishwasher you will not get hot water immediately due to the distance the dishwasher is from the water heater. You will notice when you turn on the hot water to thew sink you do not get hot water right away you let it run for a minute before it gets hot since the dishwasher is connected to the same valve as your hot water to the sink it acts the same way.
Good luck on your repairs hope this helped.
Dave
Sep 02, 2009 | AEG 24 in. Favorit 50730W Free-standing...
I have only bcold water feed but washer has hot/cold do i need 2
If it is a hot and cold fill m/c, what you need is a fitting that is referred to as a" Y" piece..To fit it, connect the straight leg of the "Y" piece to the cold supply tap, and then fit a hose to each of the two outlets, connecting each of these to the 2 inlets on the valve to the washer..
It will then fill with water, regardless of the programme you select.
You can purchase the "Y" piece connector from most hardware shops, or B&Q, and the like.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint WMA35 Front Load Washer
Washing machine
If it is a hot and cold fill m/c, then you can just use it from cold water.
You would need to fit what is called a Y piece connector , this supplys water to both hot and cold valves regardless of what prog you select..
You connect the cold supply to the straight leg of the connector, and the hot and cold to the other 2 connections.
Plz rate this solution.
Thanks.
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Can i connect a dishwasher to the hot water pipe??
In my opinion you always connect to the hot water unless there's some compelling reason not to like your dishwasher's manual says to connect to cold. Your dishwasher will heat up whatever water you have connected it to, but since you have a tank of preheated water already sitting in your water heater you should use that.
The "resin in the water softener" example, I think, makes no sense since your dishwasher will heat up the water to something like 160 degrees Fahrenheit no matter if the input is cold or hot...
Jul 15, 2008 | Dishwashers
No hot water in dishwasher
there is a heater in the base of the dishwasher . It could be this is faulty as you can still use the machine .
It does'nt matter that you have connected it to the cold water tap the machie should heat up the water it self.this is'nt a job you can do your self so you will have to call out an engineer sorry
Dec 11, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
