SanDisk Sansa E250- Only the blue light comes on? HELP????????????
Try this:
Switch your Sansa e250 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the e250 LCD screen displays "Welcome to Recovery Mode" (if the LCD remains black, keep pressing long enough -- about 10 seconds -- then proceed to the next step)
5. Connect your e250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa e250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the e250 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa e250 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
or use this Sansa Firmware Updater link:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player (or find the most updated firmware) and format it as well, thereby clearing all possible file/system corruptions that may have occurred.
Step 3:
When the process is complete, unplug your e250 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your e250 and 90-99% of the time, it would boot up successfully.
I hope this helps.
My sansa e250 MP3 player froze with the blue dial light on and a blank screen. I tried to hold the power button for 15-20 seconds and it turned off, but when I turn it back on it just freezes again as before. I took the back off and removed the battery and put back together again. Still, I get a blue dial and a blank screen. Please help...I just bought it and never got a chance to enjoy it before it froze.
same problem here . More time spent trying to make work than listening.ready to take out back and throw into woods.
