Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Click in circuit board Light in Icemaker dim bright Warm both sides
1: Refer and Freezer not cold
2: Clicking on Circuit board
3: Light on Icemaker.dims and brightens as it clicks. When I push lever on IM clicking goes away and all lights on door go out.
4:Turning fan by hand ;seems to not turn well ;hard to turn
There is no ice build up nor does the compressor or fan sem to want to come on. I have never had Icemaker hooked up to water and the switch is in the off position.
GE model GSS201EPJWW
  • 1 more comment
  • jondeere79 Jun 26, 2008
    Eagle Refrigerator and IM is Icemaker thanks
  • Anonymous Aug 25, 2008
  • Anonymous Dec 13, 2008
    ice dispencer in door doesnt work also have a clicking noise in circuit board
  • 4,889 Answers
I didnt understand what you meant by refer(refrigirator???) and IM..??
Posted on Jun 26, 2008
2004 Deville: I am getting code B 1390 - Device Voltage Reference Input Circuit Malfunction - what do I do?
DTC B1390 -The DIM has an internal battery voltage sensor and a reference voltage. The DIM compares these two voltages via the two battery positive voltage circuits every 300 milliseconds. Do you know what the DIM is ?
Conditions for Setting the DTC
This code shall be set after 10 consecutive readings that the two battery positive voltages differ by 1 volt or greater.
Turn OFF the ignition.
Disconnect the dash integration module (DIM).
Turn ON the ignition, with the engine OFF.
Measure and record the voltage from both battery positive voltage circuits of the DIM to both ground circuits of the DIM.
Compare the two recorded DIM battery positive voltage circuit voltages.
Is the voltage difference less than the specified value?
1 V
YES - Go to Step 5
NO - Go to Step 3
Test both DIM battery positive voltage circuits for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 7
NO - Go to Step 4
Test both DIM ground circuits for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 7
NO - Go to Step 5
5
Inspect for poor connections at the harness connector of the DIM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 7
NO - Go to Step 6
Important:: After replacement of the DIM perform the set up procedure for the DIM. Refer to Body Control Module (BCM) Programming/RPO Configuration .
Replace the DIM. Refer to Dash Integration Module Replacement .
Did you complete the replacement?
YES - Go to Step 7
7
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Do you know what there saying here ? Do you know where The DIM is located . Do you know where to find a wiring diagram so you know what your testing ?
free wiring diagrams at
http://www.bbbind.com/free_tsb.html Enter vehicle info year , make , model ,engine . under system click on body & accessories, then under sub system click on body controls . Hit the search button a blue link will pop up . click on that .
Dash Integration Module (DIM)
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules. Good luck !
Mar 08, 2017 | 2004 Cadillac Deville
Defrost problem folowup
bmurf, This adaptive defrost determined by compressor run time between defrost cycles. It could go up to 96 hours before defrost depending on differnt variables. With the unit running, a good frost on the evaportator and the tstat covered with frost or ice, unplug the refer. Pull the connector off the adaptive defrost board. On the harness, ohm from red to white/black stripe. If your tstat is good, you should read less than one ohm continuity. If it's bad, you probably will read around 240K ohms. This is the resistance of the resistor built into the tstat. On the live checks, plug in the refer. You are going to have 120VAC from Red to white. You also want to see 120V from white to white/black stripe. If you have that, the tstat is closed. If you have less than 120, say 96,100V. on white to red, that means you are dropping power through the 240K resistor built into the tstat. The board senses the tstat is open and no need to defrost. I hope this helps you out cat, thanks for the kind words on your post. Good luck, Catriver
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Top 1/2 of screen very dim and bottom 1/2 very bright
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 04, 2016 | Televison & Video
Hi, my side my side fridge freezer has just packed up, the temp reads cold enough but the fridge and the freezer parts are both warm :( plz help
While it could be the main control board, I would check for a defrost circuit failure first. If you take off the read shield of the freezer you will be able to see the evaporator coils. If that is a block of ice, then your defrost circuit is not doing its job and the ice is causing the thermostats to read the incorrect temperature.
The good news is that once you defrost the unit, you will have 2-3 weeks before the ice builds up enough to be a problem again. Which give you time to troubleshoot and order the replacement parts.
Jan 28, 2012 | Samsung Refrigerators
Loud ticking noise when i close freezer and lights on icemaker flash like a stobe light. fridge and freezer wont hold temp. ice amker and water dispenser dont work?
if your lights burned out recently and the digital temp read-out is now dark also,burned out lights will cause a power surge and will destroy the main-board circuit trace(mother-board), it is located in the back side of the refrigerator, in a small plastic case,when you remove it you will see a burned spot on the circuit board and the loud clicking sound is a relay on the board trying to latch to light the bulbs and operate the unit
Feb 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Door mounted ice dispenser does not work, lights dim when pushed cyclic "clicking" noise coming from back of unit which causes the lights inside as well as those plugged into same circuit to dim when it...
the clicking noise is your water valve operating, or not
if its causing the light to dim, your loosing ground
somewhere in the circuit.
juding by your diagnososis i would have to think your selector board on the freezer door is bad..
probaly a your shorted somewhere in the logic board
and thats why your loosing gorund
Oct 12, 2009 | Hotpoint HSS25GFP Side by Side...
Whirlpool refrigator side by side(2 doors side by side)
This sounds like the curcuit board has failed. No repair is able to be made to the board. Just replace the board and all should be fine..
Nov 06, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Whirlpool gs6shexns00 fridge
I had a very similar problem- flickering light bulbs, shorting-out noises, electronic temperature displays not working. I had to replace a small circuit board (the "Electronic Control Board") accessed from the rear of the fridge. A relatively easy do-it-yourself job.
Refer to this link at PartSelect.com:
http://www.partselect.com/PartDetail.aspx?Inventory=2180152&SourceCode=1
Oct 26, 2008 | Refrigerators
Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
341 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
