Question about Pioneer PD-F907 CD Player
Pioneer PD-F907 CD wont play most of the time
Will spin disk sometimes most times wont spin disk and then reads no disk will play now and then cleaned laser oiled slider.
  • 1 more comment
  • sheldon saltzberg Jul 03, 2008
    it turner out to be low RF level adjusted the rf level cotrol up works fine thank for the try
  • Anonymous Mar 26, 2014
    Pioneer laser disc Cld-v840 wont turn on
  • Anonymous Mar 31, 2014
    My CD player says there is no disc
    Sergeant:
    Champion:
  • 417 Answers
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Posted on Jul 03, 2008
Spins and reads no disc but will play some cd's
Your cd mechanism is slowly losing its ability to read all of the disks it read before. The unit is dying a slow death.
Nov 18, 2015 | Pioneer PD-F907 CD Player
My pioneer PD-M426 seems to only play disks 3 and 4 even when the magazine is full, sounds like its trying to spin the disk but failing..??
Please remove the magazine and check if there is warping within the magazine which can cause misalignment. In such a case you will need to replace the magazine . Also check all the CD's within for any damage, sometimes some spurious types can warp with heat.If so it will not load and play. Test in another cd player to confirm.Also clean the optical head within the player if this fails to read or else the optical head can be also weak.
Mar 11, 2012 | Pioneer Audio Players & Recorders
Pioneer PD-M551 cd changer won't play cds 2 thru 6.
Thank you, Mark Z! My Pioneer PD-M551 would just stop reading the CD, usually near the end of the 4th or 5th disk, and then sometimes it wouldn't read any disks or maybe only the first one or two. I observed that the white ribbon cable was most contorted near near the end of the 4th through 6th disk (also discovered the disks are read proceeding from the center outward, unlike vinyl records). I unfolded the ribbon, massaged it and left it loose and unfolded and that fixed it (at least, temporarily). The PNP-1343 ribbon cable from Pioneer costs $11 but with shipping and handling it is over $30 so I haven't bought it yet.
Jan 28, 2012 | Pioneer Audio Players & Recorders
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
CD's won't move...lights flash and CD's seem to be stuck in hold.
This usually means you have a CD stuck. I have had this player for over 10 years and have always just removed the case screws lifted the top off and removed the c\CD that is out of place (two in one slot for example) put it back together and it works fine. Hasn't really happened over 3 times. My kids got older!
Oct 26, 2008 | Pioneer PD-F907 CD Player
Power
Check fuse and/or standby power circuit.
Aug 12, 2008 | Pioneer PD-F907 CD Player
My Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
Dec 19, 2007 | Pioneer PD-F407 25-Disc CD Changer
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
606 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
