Question about Dell Latitude D600 Notebook
Bad Wireless Connection
I have a Dell Latitude D600 that just recently will not connect to my Linksys Wireless Router. Other computers in my house will connect so I know it's not a problem with the router. When I try and connect to our wireless network is continually says "Acquiring Network Address" and then a pop up tells me "Windows was unable to find a certificate to log you on to the network". It used to connect just fine but now it won't.
  • Anonymous Mar 15, 2014
    Network is showin it's connected but laptop says no connection
    Genius:
  • 2,028 Answers
This is usually caused by a driver glitch. From the device manager, uninstall the drivers for the wireless, then reboot. The machine will find and reinstall the drivers. If the problem persist, the take the card out, clean the connections, and reinstall it. It's located under a panel on the bottom of the machine. If it still won't work, then you need to replace the wireless card.
Posted on Jun 26, 2008
Wifi connection
use the advance tab settings or go to advance setting in the wireless router
Apr 13, 2012 | Dell Latitude D600 Notebook
I have a Dell Latitude D600. I can connect to the internet if my computer is plugged directly into my modem. When I disconnect from the modem and try to access the internet using wireless, I can not...
Your computer may be picking up the wireless networks in your area including yours but you still require to configure your computer to the router for which you will require to go through the manual which came along with the router/modem. If you are a computer savy man you can do it yourself otherwise you will require services of technical person.
Feb 11, 2011 | Dell Latitude D600 Notebook
Can i connect wireless internet on my Dell Latitude?
if it's a tower... you'll need a linksys pci wireless card... and a linksys router... install the drivers first... then... with the computer off... follow instructions for installing the card... connect the antenna... and then turn on. wiat for the computer to boot... it should automatically find the card... now... on the back of the cable modem... disconnect the wire that was going to the computer... and put it in the connection on the router that says "internet", now... disconnect the cable modem... wait 30 seconds... then plug it back in... wait 1 min. for everything to come up... now... connect the power to the router... and wait 1 min... go to the linksys icon in the taskbar... and double click on it... survey the site... when you find the wireless networks that are avil... choose the one that's got the strongest signal... and click connect. now... open the internet broser... and go to tools... internet options... then connections, down at the bottom... you'll see lan... click on it... you should see a box that says automatically detect settings... make sure this is checked...then click apply... then on o.k... and exit the internet.... then go back in... you should have internet...
Apr 03, 2010 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Wireless card only pics up router when right next to it
u might have to access ur router and change the channel try using 9 or 11
Aug 17, 2009 | Dell Latitude D600 Notebook
Need WPA2 wifi connection to my Linksys with Dell D600
The WPA settings on your wireless card must be the same as the setting you configured on your wireless router. This allows your wireless card to communicate with the wireless router.
Apr 07, 2009 | Dell Latitude D600 Notebook
Connecting lap top to internet
Try to connect with wireless lan to linksys router. first u shuld check ping the ipaddress of linksys router with laptop
Jobi
Feb 21, 2009 | Dell Latitude D600 Notebook
Wi Fi Connection
Have you tried this: go to bottom task bar and right click on the PC icon. Select "View Available Wireless Networks". Find and select the wireless system you have, i.e., linksys, etc., and click on "connect".
If that doesn't work, use the same method to open the connection options, and click on "repair".
Lastly, if neither of the above works, try rebooting your linksys or whatever wireless system you have, and start over.
Jan 01, 2009 | Dell Latitude D600 Notebook
Wireless connection
Hi Kazmerr
Re: Dell Latitude d600
Assuming you already turned your wireless, your distance should be in range fom your router. Turn off and on the switch  or you can press Fn+F2 to start your wireless connection.If thats a no go check your wireless client  and make sure no other wireless client is installed ie. your ISP wireless connection manager.
Other work around for this is : make sure you have enabled or started your wireless client for windows by ff the steps below :
Win XP Sp2: start > control panel  classic view> administrative tools > services > then look for Wireless Zero Configuration and right click it and choose start or restart . After doing this you may check or view your available wireless network again.IF no go >
For winXP or VIsta ONLY
Go to start > control panel   { classic view } > system > device manager > Look for network adapter {+} sign > look for 802.11g wireless / or anything that says 'wireless' and make sure that theres no yellow question or excamation mark on it and IF none right click it and choose remove/uninstall> then restart PC > and try to view avaialable wireless again by ff the steps above.
{ tthis will refresh your wireless network hardware and software}
Note: for yellow exclamation marks or questions marks on your wireless adapter you MUST reinstall your DEll Wireless adapter. using you DELL System Recovery Disk.
In most instance it has somthing to do with your wireless switch on your laptop. With all possible steps porvided above doesnt woprk pls notify me. Thanks and good luck.
Jun 11, 2008 | Dell Latitude D600 Notebook
Wireless connection in dell laptop
have you installed the driver for the wireless ?
May 13, 2008 | Dell Latitude D600 Notebook
Dell D600 - Linksys wireless router/adapter
Seems there is a problem with the Linksys since there is not any lights coming on. Did you plug it into a switched outlet in the wall? Does it work if you plug the Linksys into an outlet in another room?
If you can get it to light up, the way you will access it is through your web browser. Type in 192.168.1.1 into your web browser and a login in screen should pop up.
Apr 28, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
236 people viewed this question
Alun Cox
