Question about Dryers
Dryer not heating
Why would this keep happening? this is now the 3rd time
  • 413 Answers
If airflow is poor through the exhaust, the heater will fail and other protection devices, intended to prevent fires, will fail.
Check the exhaust hose in the rear of the machine and make sure it it not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic. If everything in rear looks OK, check the outside vent hood for any blockages. If everything checks out, the exhaust system may need cleaning. Cleaning kits are available at most home improvement centers and at this web site: http://www.linteater.com/.
Posted on Jun 26, 2008
Where is the reset button for the heater
Most dryers do not have a reset button for the heater. No heat can mean several things. !st--heater may have burned out and needs replaced. 2nd-- some dryers have a thermal safety thermostat that if the dryer gets too hot it will trip off the heater. Usually it needs replaced when this happens and you need to see why it overheated like possibly a blocked vent pipe. 3rd-- no heat could be from a bad heat select switch, a bad operating thermostat, or a bad timer. You need to have some knowledge to trace the problem down and know how to use a multimeter for testing.
May 09, 2015 | Hotpoint Dryers
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Estate Dryers
Gas dryer/ has just started taking long time to dry each load needing multible cycles of time. Is generating some heat, vent is clean, trap iis clean. What is keeping the dryer from heating up?
I suspect your gas valve coils are going out and need to be replaced. They can work when first used but later in the cycle one of them quits.
Sep 23, 2011 | Roper RGS7745PQ Dryer
Dryer keeps going out - 3rd time since January. It tumbles but no heat. I've replaced the thermal cut off #279816 and the element #279838. I cleared out the vent all the way to the roof. I've...
Hello this will be a bit of an odd question at first but have you ever dlinted your dryer? Just as your dryer vent does get a build up of lint the dryer does as well. Click this link to view a tip I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer the most important area to clean is where the blower goes into and you get at this area by removeing the rear panel of the dryer if your dryer is a type like whirlpool, kenmore, maytag all dryer need to be dlinted at least once per year to maintain the dryers ability to dry. If I am able to bring a 45 year old dryer back to life by doing this you should have no problem If you have any questions message me back this will require also the tub being removed as well but I can guarantee if the air is unrestricted the heat is able to travel unblocked and it doesnt cause blown thermistors as well . Thanks Rick
Aug 10, 2011 | Dryers
I inherited an older model whirlpool electric dryer when I moved in...there seems to be no heat...went to get clothes out this morning and they were still damp...I wasn't given a manual - and have...
Check the breakers, by FULLY turning it off and then back on. What happens, commonly, is the heat side of the 220 breaker trips. If it keeps happening, sometimes you need a new breaker, but DO NOT increase the amp rating of the breaker. Breakers that trip from time to time, eventually start tripping EARLIER.
Jun 10, 2011 | Whirlpool Dryers
I have a whirlpool dryer M460-G (SN#MH4612126 ? LGR7646EQ3). The dryer does not heat up. I checked the back and cleaned all the lint. The gas ignites and heats some time but not all the time and when it is...
Replace your gas valve coils!! They will allow the dryer to heat initially, but fail after about the 3rd or 4th iginition sequence.
Part number 279834 and are around $20.
They are located on top of the valve and held on by a steel bracket with two phillips head screws. Plug and play wires you cant mess up.
Fix it up!!
Aug 14, 2010 | Roper REX4634KQ Electric Dryer
Frigidaire dryer AEQ7000EGO not heating up
you need to make sure you are getting 220, your dryer will run on 120 but not heat.
2nd check fuse that is located inside dryer near drum
3rd check heat elements for breaks.
Sep 12, 2009 | Frigidaire AEQ7000ES Dryer
Thermal fuse keeps blowing
Good Afternoon,
Unless there is something restricting the ventilation I think you are having a problem with the heating coil staying on too long. If that is the case, one or more heating sensors are bad. Let me know if this helps and thank you for using FixYa!
Nov 25, 2008 | Amana NDE2335AY Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
