Question about Radio Communications
Motorola XTNiD I have several of the new Motorola XTNiD's and a couple of the non display XTNi which, when switched on, make no sound but the red TX light comes on and stays on. No Audio or TX output. This seems to be a error code, has anyone else had this problem and if so did you manage to find the fault?
  • Michael Ashby Jul 11, 2008
    This is a fault and not a programming issue. I have repaired about 30 of these units, but this fault has me stumped and it seems to be a common fault as I have about 9 of these with the same fault. (XTNi and XTNiD versions). Has anyone else come across this and found a fix?
    These are the replacement for the Motorola XTN licence free radio.
  • vulcansr2 Dec 20, 2008
    I purchased 3 2nd hand XTNiD's to supplement my xtn & CLS PMR equipment. 2 have developed the same snag. - switch on led remains red with no function - LCD screen blank. As this appears to be a common fault with the XTNID has Motorola come up with any suggestions.
  • 21 Answers
I have narrowed this down to the processor and sucsessfully changed about15 processors, This solves the issue of the radio having a perminant red LED.
Posted on Dec 16, 2009
  • Mike Ashby
    Mike Ashby Feb 11, 2010
    Protea Electronics offers a fixed price repair service for these radios. £33.00 for the XTNiD and £30 for the XTNi plus return shipping of £4.00. UK Mainland only, for other areas please ask for a quote on return shipping.
    Find us here
    Sergeant:
  • 250 Answers
Hello Umtali,
What you describe could be the result of the radios being incorrectly programmed by the dealer. Like most professional radios, the Motorola MTNiD requires delaer programming (using computer software) to set the channels and functions of the radio. If the radios were not programmed or were programmed incorrectly then an error such as the one you mentioned might occured.
You should contact the dealer about getting the malfuntioning radios reprogrammed. Or, you may be able to clone any working radios you have into the non-functional ones using the cloning procedure in the User's Manual.
Best Regards.
Ken
"Go Ahead. Use Us."
Posted on Jun 26, 2008
Have the same problem, this is not a programming issue as the CPS does not communicate with the radio. The fault seems to occur after some time in use, so for sure is not a programming error, it just fails in this way!. All the regulators seem to measure correctly and the CPU has power and the clock runs. I can only assume that the CPU is faulty or there is a problem with the flash memory. I would be interested if anyone else has some clues.
Posted on Nov 21, 2008
My xtnid 554 turns on but has no display
Check your battery pack. The display is one of the first things to go when using a bad or poorly charged battery. Test by trading batteries with another known good unit. If this does not solve the problem, your display is bad.
Apr 10, 2014 | Motorola Walkie Talkie 2-Way Radio
Motorola xtnid not transmitting
This can be a sign of a bad or poorly charged battery. Trade batteries with a known good unit to see if the battery solves the problem.
Secondly, check your programming to be certain the radio is programmed to match the others.
Lastly, if neither of these solve the problem, your radio is likely in need of repair.
Feb 24, 2014 | Motorola XTNi Two Way Radio
Where can I get an operation manual for this item
You can visit this web page , and on the extreme right hand side you will find the user guides and operation manuals for this product..
http://www.motorola.com/Business/XU-EN/Business+Product+and+Services/Unlicensed+Two+Way+Business+Radios/XTNi+Series/XTNi_XU-EN
Jan 06, 2012 | Motorola XTNi Two Way Radio
Need xtniimanual manuals
First of all, thank you very much Colin for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNi%20Manual%20EN.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Intermmitant transmission on a Motorola xtni radio
Intermittent transmit can be caused by:
1) Bad or poorly charged battery. (try a known good battery and see if the problem clears up)
2) Poor connection to the battery. (clean all contacts with a pencil eraser)
3) Bad PTT internal button, radio would need repair.
4) Bad antenna. Check for breaks in the rubber covering.
5) Other internal problems requiring repair.
Best regards.
Mar 09, 2011 | Motorola XTNi Two Way Radio
Walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
Feb 06, 2010 | Radio Communications
Motorola xtr446 can not get rid of icon on phone that has disabled speaker
You may be referring to the circle with a slash through it, which is the scramble emblem. Here is a link to the user guide http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Refer to page 41.
This may help you resolve your issue. Best regards.
Dec 12, 2009 | Radio Communications
Motorola XTNi off frequency
There are several ways:
1) Customer Programming Software (CPS)*
Allows users to perform various programming
functions. Plus, the CPS software provides access
to new features such as Radio Reporting to
manage cloning and radio profiles, Manager Lock,
Power Select, and Time-Out Timers.
* CPS is available as an optional accessory, including required USB cable.
2) Easy Cloning
Quickly copy settings from radio to radio with
either the Radio-to-Radio Cloning Cable or the
Multi-Unit Charger accessories. (Both sold
separately.)
You should be able to purchase any of this software/equipment from your retailer where you purchased the radio.
Best regards.
Dec 03, 2009 | Motorola XTN 2-Way Radio
Motorola XTNi two way radio red light on all the time
The XTNi is a European version of the Radius CP110 and the Spirit RDX series. This unit is user-programmable. It is possible the radios you have with the same symptoms have a programming issue.
There are 3 ways to program the radio: 1) using the CPS software and cable, 2) using the 6-unit charger as a cloning station, or 3) using 2 single unit chargers linked together via a cloning cable. It is also possible to change limited programming features by hand.
We suggest you take one of your XTNi radios which is functioning correctly and clone the codeplug (copy the programming) into the non-functioning radios to see if it clears the problem. If not, the unit should still be under warranty. Take it back to the place where you purchased it and see if you can get it repaired under warranty. (This unit has only been available for about one year, so yours should still be under warranty.)
One other issue might be effecting the radios, which would be rare to happen on more than one radio at the same time. This would be "lock in transmit". You could tell if this were the case, because the radio's display would not change when you press any of the buttons. This problem would also require repair.
Sep 18, 2008 | Radio Communications
Radio Communications Logo
955 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
