Question about Toshiba 32A41 32" TV
My Toshiba will turn on and off but nothing shows up on screen
Our tv was accidentally dropped face down and now nothing will show up even when I switch video or change the channel. Is there something I can do to fix it at home or should I take it to a repair place.
  • Toshiba Master
  • 5,568 Answers
Although CRTs are pretty tough, depending on the height of the drop, it may have lost vacuum.
If it is the CRT, I think you would find the replacement cost unreasonable.
If a CRT loses its vacuum suddenly, it will normally show some signs of the phosphor of the screen flaking off spotwise.
Look for this before bothering to go any further.
Leave the set unplugged overnight to ensure that there aren't any dangerous voltages exposed.
Then, what you can safely do at home is to place it face down on some carpeting, remove the few screws holding the back panel on and do a thorough visual check of the guts.
The CRT can retain high voltage for several days; while this isn't necessarily lethal, it can burn a hole right through a finger. If you have a bit of flexible copper wire, you might want to wrap bare ends around a small screwdriver shaft and attach the other end to ground, any bare metal of the chassis.
Slide the flat end of the screwdriver under the large, flat, rubber cap located on the CRT. This cap will have a heavier insulated wire connected to it that supplies the accelerating voltage to the CRT.
The base of the CRT will have a board plugged onto the base of the tube with a number of wires attaching it to the main board..
Carefully remove this board and plug it back in again.
Using good light, inspect the main board and any other plugged connections you can find.
If you can access them try to remove and return them to their mating connector.
Use caution; the boards used for TVs aren't very durable so try to avoid stressing them while doing the above.
If you see wires not attached to anything (unlikely), search for a mating connector.
If your time has produced no positive results, you will have to consider whether the set is worth the cost of an estimate, assuming you can find a repair shop still in existence.
Good luck-
Posted on Jun 26, 2008
All my tv shows a a blue screen nothing else even when I press input
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 14, 2015 | Televison & Video
Toshiba Satellite A200 - Logging In
Please restart in the safe mode once.And run a virus scan after that turn off your laptop and turn it on again now don't go into the safe mode just start the windows normally,enter your password and see if you face the same problem.
Jun 24, 2008 | Toshiba Satellite A200-0ET00X Notebook
My dell latitude E6430 displays a black screen when turned on only background lights of battery and wireless network is showing. please help me to figure this out.
I had the same problem on an old Toshiba, accidentally I found out by holding my Fn (function) key down and the 'F5' key (to change to external monitor causes my screen to display once again.
Aug 12, 2014 | Computers & Internet
Toshiba camileo H10 camcorder. No picture. Screen shows Zoom 1 fail E AF PI fail /.
Hello Charles,
Just to be sure it is NOT a software issue, remove the battery then replace it back after about 5 minutes and then try turning it ON again.
The error you are getting is a "zoom error". A problem connected with your camcorder's optical zoom not working, it is either it has broken parts or something is caught in the zoom mechanism.
If something serious happened to it, like if it was dropped accidentally or a force was applied to it, then it is probably broken parts inside and needs servicing. Otherwise, it could be just dirt or sand stuck inside the mechanism.
To try and resolve the problem with dirt/sand you can:
Hold the camcorder with the lens facing the ground, then tap the side of your camcorder repeatedly.
OR
Use a canned air and spray it into the lens area of your camcorder.
Oct 21, 2011 | Toshiba Video Cameras
Hi I have a toshiba dfs 100 hyper progressive rear projection 67" tv, model 61A9UA and when i turn on the tv rows of what look like are black small rectangular boxes appear. Its still there wether i...
hi i have a Toshiba Dfs 100 & hyper progressive i hve no idea what wrong with my tv.. when i turn the on button the box down the bottom its on nd showing blue color..**** nothing showing on the screen.. pls help me thnx
Aug 09, 2011 | Toshiba Televison & Video
My toshiba l500-02h is only showing blank page with booting.
Hello, Does it sit there and do nothing? Sometimes all that is needed is the battery pulled (disconnect power cord as well) Press and hold the power button down for about 5 seconds. Put battery back in and connect power cord. Now try booting. If nothing shows on the screen, the next step would be to connect an external monitor or TV (if you have one) to the VGA or HDMI port. If a picture shows on the monitor / TV but still not on the laptop, you may have a burnt out display... which is expensive to fix. You may find some good prices for screens on dbay.
Chris
May 11, 2011 | Computers & Internet
I turn my computer on and
Hi there
The black screen that appears before the booting asking for password shows that you have activated security password through BIOS settings.
If nothing is working implies that you don't remember the password or activated it accidentally.
The only solution to your problem is to get into the BIOS settings an deactivate the security password or reset the BIOS settings.
thank you
Jul 24, 2009 | Toshiba Satellite A135-S2386 Notebook...
Ipod Nano doesnt turn on AT ALL
turn hold on then off, then hold down menu and select untill screen shows apple symbol.
Jan 15, 2009 | Apple iPod nano
My Wii is TURNED ON but not showing on the screen!!
Dude, you must have broken something inside of it. Phone nintendo.
May 17, 2008 | Nintendo Wii Console
Toshiba 32A41 32" TV Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
