Question about Amana AFD2535DES French Door Refrigerator
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
4 years old. 10 days ago, freezer stopped freezing. Kept hearing a clicking noise, like a switch, go for 10 seconds or so then stop. Would do this every five minutes, but freezer no longer freezing. Took everything out, called the repairman. By the time he showed up 2 days later, the freezer was again working, he was unwilling to do anything. 4-5 days with freezer OK.
2 days ago, freezer stopped freezing again. Same clicking noise.
Yesterday I noticed the inside refrigerator french doors - a lot of heat coming from both surfaces where the doors meet. Refrigerator getting warmer, got up to 60 degrees. Took all of the food out. This morning, freezer partially freezing, refrigerator at about 45 (warmer than usual).
Repairman coming tomorrow, what can I tell him? Something's obviously not right. I've read a few other posts here, mine is very intermittent.
  • robbiegray Jul 10, 2008
    Thanks, this is exactly what the repairman figured out also. Fortunately, it was misbehaving when he was here,
    Thanks for responding! We're all fixed now..
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Posted on Jul 10, 2008
  • 1,435 Answers
Brother,youdon't need a new fridgejust rplace the fan motor underneath in the back.It blows air across the coils at bottm of fridge and turns compressor on to make cold when temp is change in system.The clicking sound is the relay to the fan that is burnt out.Been there,donethat,got the TShirt.Rigger.
Posted on Sep 28, 2012
Repairing freezer drawer slides on amana afd2535dew
if gear wheels are out of sink, give it a good twist till equil.
ifb it is the ballbearings in the rails replace hole rail, wize to do both sides at one time.
Apr 07, 2014 | Amana AFD2535DEW 25 french door bm...
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
I have an Amana AFD2535DEW. It is over a year old but the top has quit cooling, but the freezer is OK. It did this before, but I was told to let it sit over night with out opeing it. That seemed to...
Mine did the same thing about two years ago. It turned out, my problem was the little motor that opens the vent in the refrig portion to let the cold air in from the freezer went bad. A&E service tech said this was common. Cost about $90 to fix. Haven't had the problem anymore.
Aug 03, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ABC2037DEB after 4 years, now freezer click and hum melting
that click followed by a hum can only be one thing
pull the unit out and feel the compressor, if its really hot you have a relay and overload issue, and it struggles to start.
with any luck, it is the external relay and overload found mounted to the comresssor should be a lil white block
if not it will be two differant parts
a lil white one and a brown one
let these cool a bit and check both for continutity
ive included a link for the parts
they are 10 and 11 on the schematic
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174380&diagram_id=1358665#d1358665
Oct 22, 2009 | Amana ABC2037DEW / ABC2037DEB / ABC2037DEQ...
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
My Amana AFD2535DEW freezer problem
Sound like the compressor is having trouble starting. You can purchase a RCO810 to assist the compressor's start winding. If the unit is under 5yrs there should be some warranty (no electrical parts) left in the compressor. It will need to be replaced.
Oct 16, 2007 | Amana AFD2535DES French Door Refrigerator
Amana AFD2535DES French Door Refrigerator Logo
523 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
