Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
No water to ice maker
We have a kenmore model 106.74252400. there is no water coming into the ice maker. we are getting water to the dispenser and to the filter. just took ice maker out and did not see any problems. all fans are working. freezer is freezing all other things. just not getting water to make ice. No water in Ice maker. Cycle will not start.Water dispensor OK. Water vales OK. Pulled Ice Maker unit, powered with 110 ac,everything looks OK.
  • 2 more comments
  • rbgris63 Jul 28, 2008
    Solution # 1 does not apply because I always keep my coils clean.
    Besides the water not filling the tray which should start the cycle right after ice being dumped, I noticed the red light next to the
    sensor beam binking two times. The trouble
    shooting sheet indicates this as a problem with
    the sensor beam being blocked which it is not.
    Could there be a problem with the sensor beam
    circuity.
    Richard Griswold
  • jkslade Nov 17, 2008
    i just changed out my ice-maker. it has been an hour...when will it fill?
  • strtserv2 Dec 06, 2008
    Ice maker not filling. I thawed the ice plug at the black rubber filler tube, and changed the filter.  I also reset the water filter system "yellow light" now green.
       There does not appear to  any reason for no ice, any suggestions.  This is a Kenmore side by side with a door dispenser for water and ice.
  • Anonymous Jan 11, 2009
    i have a frigidare refrigerator,they are installing a culligan good water machine in our home tomorrow. it will have a seperate line for drinking and going to the icemaker. can i get rid of my filter in refrigerator and run it direct. if so how?
    Genius:
  • 1,665 Answers
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    • Kleanthis Mavropoulos
      Kleanthis Mavropoulos Jul 28, 2008
      http://www.repairclinic.com/SmartSearch/...
      The water-supply line enters a valve in the refrigerator that is controlled by an electric solenoid and sends water through a fill tube into a mechanized icemaker assembly. There, the water freezes and is dumped into an ice bin. When the bin is full, the ice lifts a bail wire that turns off the icemaker.
      If the water's route is blocked or the solenoid doesn't work—or if the bail wire is lifted—the icemaker won't make ice. Also note that your home's water pressure must be strong enough to serve the needs of the icemaker (see your owner's manual).
      Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
      1) If the icemaker doesn't make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn't arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn't kinked behind or beneath the refrigerator (Ό-inch copper tubing is much better than plastic fill line).
      2) Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
      3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
      4) Check the tap valve; a bad tap valve may cause the problem where the icemaker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a Ό-inch hole (as opposed to the "self-piercing" type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
    We had a problem with ice maker not making ice. After alot of concern it turned out we just needed to replace the filter.
    Posted on Aug 07, 2008
      Guru:
    • 1,894 Answers
    A refrigerator or freezer that doesn't cool well enough may have a problem with its evaporator coils, condenser, or condenser fan motor. Frost build-up on evaporator coils, or condenser coils that are covered with dirt, dust, or lint can reduce how well a refrigerator can cool. If you notice ice getting thicker on the inside walls, inside bottom, or inside ceiling of the freezer, you have what is called a frost build-up. The problem is either with warm, moist air getting in through an old inefficient door gasket or the defrost system.
    Self-defrosting refrigerators have coils and a cooling fan that need to be cleaned regularly. If the coils get coated with any contaminants, they may not cool the refrigerator properly. The coils are usually thin and black and they go through fins that dissipate heat, just like a car's radiator. They are located behind the lower kick-panel or on the back of the refrigerator. To clean them, turn the power off and use thiscondenser coil cleaning brush, or this condenser coil cleaning brush , and your vacuum cleaner. Even if your coils are below the refrigerator, you won't be able to get to all the condenser coils from the front, so it's a good idea to pull the refrigerator out and clean the coils from the front and the rear of the refrigerator. Give the fan a dusting as well. Sometimes other things can be the reason behind poor cooling, like the condenser fan motor. Anytime the freezer fan is running, the condenser fan should also be running.
    A frost build-up inside the refrigerator usually means that there is a problem in the self-defrost system. You may even have damaged door gaskets. When you open the refrigerator door, you also let in a blast of warm, often humid air. This moisture usually freezes onto the evaporator coils immediately. Self-defrost refrigerators are supposed to self-defrost between two and four times out of every 24 hour time-frame. They basically turn off for a few minutes several times a day. A defrost heater kicks on to melt any frost build-up on these coils, which allows the frost and ice to melt, then it drains off to the pan underneath most refrigerators. Unfortunately, when a defrost component fails, too much frost builds up on the evaporator coils. When this happens, the circulating fan can't draw air over these coils. With no air flow over the evaporator coils, the refrigerator compartment will lose its cool.
    To determine if the self defrost system is faulty, it's best to remove all the food from the refrigerator and freezer, turn your thermostat to the Off setting, and just leave the doors open for 24 to 48 hours, and let the refrigerator defrost. Keep an eye out for an overflow of water from the drip pan on the bottom of the refrigerator.
    After everything has completely melted away, set the thermostat back to a regular setting. If your refrigerator starts operating properly, the symptoms lead to there being a problem with one of three other components in the self-defrosting system, the defrost heater, the defrost timer, or the defrost thermostat.
    If, after testing these components, the refrigerator still doesn't get your foods cool, there may be a problem with the refrigerant level and you will need to contact a professional appliance repair person.
    Posted on Jul 27, 2008
      Brigadier General:
    • 3,614 Answers
    It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off.
    Posted on Jun 26, 2008
    • micromaster
      micromaster Jun 26, 2008
        • If your ice maker has a small red plastic lever, lower it to lower the wire.
        • If there's no plastic lever, simply lower the wire.
      • The ice maker head assembly may have broken
        parts. Look to see if the gears are broken. Check to see if the small
        plastic arms that rest against the ice rake are broken. If the ice
        maker head assembly is modular and you've found broken parts, you can
        just replace it.
      • The
        ice maker fill tube may be blocked with ice. If so, melt the blockage
        using a hair dryer-but be careful to not melt any plastic parts! Also
        replace the water shut-off valve or water-inlet valve, or both, if
        necessary.In
        either case, the ice maker should begin producing ice again. Also make
        sure that the temperature is 8 degrees Fahrenheit or lower. If the
        freezer is too warm, the ice maker won't cycle properly.
      Master:
    • 497 Answers
    There r two possibilities..1.. being the fill nozzle is frozen. Thats the little black rubber hose hanging down from the ceiling of the freezer above the icemaker.2...the icemaker gear cud be broken . The ice maker will have to be removed to check this. Hope this helps!
    Thanks for using Fixya
    2 Suggested Answers
    • 1894 Answers
    SOURCE: no water to ice maker
    This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues.
    If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
    Posted on Aug 11, 2008
    My kenmore side by side is not making ice
    when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
    Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    We find black particules in our ice
    Hi, I'd investigate the water filter first. At least identify whether your water supplying the ice maker is in fact filtered. Some model's filter only the water dispensed into your glass for drinking but not to the ice maker. If your's does indeed filter the ice maker water, it may be particals from the charcoal filter, at least that would be my suspicsion. Let me know if I can assist you further. If so please provide a model number. Thanks for coming to "fixya" for your trouble shooting inquiries. Please take a second to rate the solution I provided for you today. Good luck macmarkus :)
    Mar 14, 2010 | Kenmore Refrigerators
    No water coming from water dispenser.
    It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
    Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Water will not dispense to ice maker
    The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
    Thanks Kel
    Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
    I can get water to the water dispenser in my side by side. but it will not make water. It's a Kenmore 22 side by side. I believe the model number is 9522611. We switched the wires on the solenoid and it...
    the inlet water valve has a screen on the inlet in the valve which is probably clogged - replace the inlet water valve with a new one, install a ice maker water filter in the water line feeding the ice maker!
    Jan 15, 2018 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
    Ice maker works but not water dispenser
    Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
    Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
    May 05, 2009 | Kenmore Refrigerators
    Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
    There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
    Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Kenmore side by side refrigerator
    there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
    Nov 03, 2007 | Refrigerators
    Kenmore Side by Side Refrigerator Ice Maker Not Working
    A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
    Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
    3,223 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    Arnel
    Arnel
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
