Question about Neff 24 in. S5456 Built-in Dishwasher
Neff Built in Dishwasher
I have a 10 year old Neff built in dishewasher i am not sure of the model no but on the back of the booklet that came with it says S5443.The problem is that just recently every time you open and close the door the bottom left hand swinging arm hinge seems to be catching on something and is making a clicking noise.I cannot see how to get access to this area to see if the hinge is broke or has become detatched or if i could is this fixable?. I would be very grateful for any help you could offer.
    President:
  • 1,462 Answers
Take top off then side panel and hinge is exposed. to expose the part of hinge on door, take outer panel off door - just held in by screws down each side
Posted on Jun 26, 2008
S5443
there should be screws inside the door at the top and sometimes even on the sides depending on the quality of the person who installed it. after removing all the screws turn off electrical breaker in power box. unplug cord if visible under sink. also unhook drain hose and the pull washer out while feeding cord and hose through wall of cabinet.
May 08, 2014 | Neff 24 in. S5456 Built-in Dishwasher
Neff S5443 dishwasher needs to be reset
If the machine is pumping when on but door is open this indicates that water has gotten into the base (under the tank) and activated the flood safety device. You need to get the machine out, pull on to a towel and tip forward ('lift back feet off the floor approx 45 degrees and let the water flow out. This we deactivate the safety and the machine should now work ok.
Apr 12, 2013 | Neff 24 in. S5555X0GB Built-in Dishwasher
Can I plumb a s5443 into a Hot water supply.
Thats the only line you need to install dishwasher,you need the hot line and not a cold,the hot is for the heat that is needed to thoroughly clean the dishes.
Oct 16, 2012 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a s5443 neff dishwasher no lights coming on and nothing happening. fuses ok in scockets
could be your mains surpressor or main board on the appliance. check for continuity from the plug to the board if you have it then it is not the surpressor it will be the board. if it is the board you need to find what part has caused the board to blow
hope this helps
Nov 11, 2011 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff built in dishwasher not draining. removed the filter and theres a well hole full of gunk. How do I empty it? Dishawher about 10 years old not sure of model number
Hello, sfd
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Sep 09, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
Dishwasher S5443 is not filling with water
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Nov 15, 2010 | Neff Dishwashers
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
I replace torn outlet hose on my Neff S4438 built
make sure you still have power going to your unit. sometimes they are plugged into a regular wall plug under the sink or you can also chrck the circuit breaker @ the panel most of the on the out side of the house
Oct 25, 2009 | Neff 24 in. S4443 Built-in Dishwasher
Microwave turns itself oo
it sound like the inverter unit is faulty or the magnetron is gone.the only real way to find out which is to change each one in turn,sorry i cant be any more help.if you have any more questions get back in touch,regards les
Jul 28, 2009 | Neff Microwave Ovens
Neff 24 in. S5456 Built-in Dishwasher Logo
468 people viewed this question
Top Neff Dishwashers Experts
shaun taylor
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
