Question about Whirlpool Kitchen Ranges
Whirlpool Gas Range Model 9756385. While away from home for three weeks, we were notified that there was a smoke situation in our home that resulted in the local fire department pulling out the range and shutting the gas. No one was home at the time. Indeed, no one had been home for three weeks. There was significant smoke damage, but nothing attributable to flames. My daughter went to the house as we are still out of town. With the gas turned off, she noticed that the oven was still too hot to touch. She saw that the range was still plugged in to the AC power, so it was disconnected. From the preceding it seems that some electrical part in the oven came on and heated up to the point where some part(s) melted (there is some charred material in the lower oven drawer). I did some online reading and found that Whirlpool had replaced a relay with a double relay in a strikingly similar situation. Is there any documentation on such occurrences. The range is just over two years old.
SOURCE: clock,timer and oven does not work on Kenmore gas Range
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
Posted on Mar 11, 2008
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
Posted on Oct 22, 2008
SOURCE: Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
Call the manufacturer. Chances are it's a common problem and they already know about it.
Ben C.
BensDiscountSupply
Posted on Nov 04, 2008
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
  • 139 Answers
SOURCE: Hotpoint gas range model RGB7458EAIAD oven won't heat up.
probably a bad thermostat
Posted on Dec 28, 2009
Three of my smoke alarms blink since i canged the batteries after one chirpped. the other tw have a steady gree light. why?
It would be nice to know if all the detectors are the same model and/or manufacturer. I have been in a number of homes where the smoke alarms have been replaced one at a time resulting in different models. If possible, please add a list of the models involved and ages of devices...if more than 10 years old, replace the unit.
Mar 16, 2016 | Home
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ...
www.appliancepartspros.com > ... > Range > Whirlpool Range Parts
$18.90
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
[PDF]GAS RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
Problem with motor dealer,repairs on vehicle
notify and make a complaint with the corporate office of dealership unless its a private used car lot and than notify a lawyer
Apr 15, 2013 | Jeep Grand Cherokee Cars & Trucks
Oven is Electrically charged Or Uses LPG domestic Gas?.
GS460 is not the full model number for the range. The range needs both electrical power (120V AC) and gas. The electric power is used for the burner igniter and controlling the range thermostat.
The GS460LEK can be used with either NG or LPG. It came with the NG orifices installed at the factory; a conversion kit needs to be installed to use LPG. (The cap in the regulator also needs to be turned 180 degrees to read LP.) This should be done by a trained installer. Most Whirlpool ranges will have the conversion kit attached on the back of the range near the regulator. See the installation guide from Whirlpool for your model, try https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=m3wLp9EUOpUUfCAXtvB5kw%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
The installation guide for the GS460LEKQ0 is available at https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%208522956.pdf .
I hope this helps.
Mar 28, 2012 | Whirlpool GS460 Gas Kitchen Range
Whirlpool 465 accubake gas range stuck in the "lock" mode.
Hi, Try setting it to clean, then cancel the clean cycle right away. Sometimes this helps. Please let me know.
Thanks
Vic
May 17, 2009 | Whirlpool GR460 Electric Kitchen Range
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Aug 20, 2008 | Whirlpool GS460 Gas Kitchen Range
Range goes into lock out mode for no reason
I posted a similar problem earlier today but never saw it come up. Anyway I found the problem for me. My problem was a "LOC" display came up when I plugged the stove in after bringing it home (bought used off craigs list). This made the stove top inoperable, no gas supply.
SOLUTION:
There is a Cooktop Lockout as part of the night light switch which you hold down for 3 seconds to activate or deactivate. This is not the same as the Control Lockout which is next to the switch I am describing. Anyway doing this will make the "LOC" display go away and you will hear the gas valve activate or deactivate respectively.
Jun 14, 2007 | Whirlpool GS563LXSS - stainless Steel Gas...
Kitchen Ranges Logo
117 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
