Question about IBM ThinkPad T40 2373 Notebook
Fan making noise help
Fan error message on start up.. how do I resolve this? thanks...
    Genius:
  • 2,028 Answers
Start by taking the machine apart, cleaning the fan, and checking the connection. The failure may be due to debris buildup or a loose connection, and I've also seen fans stop working because a hair has gotten wound in them. If it still doesn't work properly after cleaning, then it will need to be replaced. Here's a link that has breakdown diagrams and instructions, this should help.
http://repair4laptop.org/notebook.html
Posted on Jun 26, 2008
How do i fix error code 0xc05d0281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d0281-error/td-p/615959
Sep 01, 2014 | HP Photosmart C6180 All-in-One Color...
My Lexmark printer when turn on it makes noise and it can not print with a error code 2200
Hello thanks for using Fixya
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Step1.
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes:
Continue to step 2.
No:
Attempt a test scan. If the error message does not reappear, the error is resolved.
Step2. Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.Did the error message return?
Yes:
Continue to Contacting Lexmark.
No:
Continue to step 3.
Step3: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes:
Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No:
Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Step4: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes:
Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No:
Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark P4350 All-In-One InkJet Printer
My fan has been making noise but it went away ... Last night I closed down my machine and when I opened it this morning I get a message fan error ... I assume that I need a new fan ... Please confirm and...
It depends on the fan type (power supply fan, processor fan, enclosure-mounted fan) and whether you are technically savvy to replace it yourself. Fans can cost anything from $3 to $30, depending on size and quality.
When you establish what kind and size of fan you need, you can buy it in any online store with computer/electronics parts.
Sep 19, 2010 | Computers & Internet
THINKPAD G41 Fan Error
Hi
Thank you for your query
You are right when the laptop first starts up it is the fan, if you are getting error message then it is the heat sink (fan on top of cpu) that will need to be replaced.
I would only recommend changing it if you know how as getting to the motherboard is quite tricky to say the least
Please dont listen to the geeks at bestbuy, they obviously dont know what they are talking about
If this has been useful please leave positive feedback/vote/testimonial - Thank you again
Feb 13, 2010 | IBM ThinkPad G41 Notebook
Getting an error on my Samsung DLP model HLS5086W. Error ''check Fan No 2'' Two qustions: I can't find any information on this error online or in the manual. I want to know where to check it and how to...
If you have removed the back of the set, or if you do, you will see that all of the fans hook to the digital processor module right in the middle of the set towards the back. There will be the fan connections on the right hand side. Follow the connections of the second connector down (this will be fan #2) to the fan, and that is the one that is causing the error. Note that the fans are a three wire hook up and you will need to replace them with a simmilar fan. You may want to replace any fan that is noisy or is slow while you are in the set.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Oct 29, 2009 | Televison & Video
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Aug 08, 2008 | Panasonic Home Theater System System
My computer started to have this weird noise about 3 weeks ago. when it started it wasnt everyday and I would re start and it would stop. About 4 days ago it started and doesnt stop. Its a constant noise,...
Hello aneleopolski,
It could be that there is something obstructing the fan, as this is the major source for noise from a PC.
If you know how, open the side panel of the PC cabinet and inspect the fan. Make sure the fan grille is not dented or touching the fan in any way. Also make sure that the fan is in an exact upright position, as even a slight tilt can cause the fan to create a noise.
Make sure there are no loose parts in the cabinet, small pieces of plastic, loose screws, etc. Also make sure that when you replace the cabinet panel, there are no wires touching the fan grille. If there are wires running around the fan, try to tape them together and to the panel away from the fan.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 25, 2008 | Computers & Internet
Error message er if
Hi. Error FF is your Fresh Food Fan. Otherwords, the evaporator fan motor has failed. You should replace the motor and motherboard. You may get by just replacing the motor. Sears doesn't manufacture the refrigerator. They just pay extra to have Kenmore put on it. Its the manufacturer that needs to back their equipment. If you bought it from Lowes, you can't hold Lowes responsible for the ongoing issue. They sell the same refrigerator. Anytime this model refrigerator displays an Error code, unplug it for 5 miniutes and replug it. Sometimes it was a computer misfuction. Good luck! Mack
Dec 28, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
IBM ThinkPad T40 2373 Notebook Logo
108 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
