Question about Samsung SCX-4725FN All-In-One Laser Printer
Scanning multiple pages
When I scan multiple pages via the feeder, a solid line appears down the middle of each page. The line does not show up if I open the lid and scan each page manually.
  • Anonymous Mar 12, 2014
    TONNER EMPTY ERROR SHOW NOT SCAN FOR MIDDLE OF PAGE
    President:
  • 357 Answers
Hi there
This could be one of many problems, i will tell you a few solutions that i know of, check the lid and see if there is a bulge in the middle of the lid (is the lid uneven in anyway?), if it is, i would suggest that you return your printer to the place where you bought it. This could also be a setting on your printer, the setting could be to scan a book or to scan two smaller pages.
If you would like a manual on how to sort this out (if the problem persists), please e-mail me at dustin_ellse@yahoo.co.uk
Kind regards and good luck
Dustin Ellse
Posted on Jun 26, 2008
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
My Canon MF4150 multifunction device started displaying streaks (or black vertical lines) on pages scanned via the ADF. These streaks appear when scanning from Windows 7 (64bit home premium) as well as...
Hello I just figuered out this problem. When the paper is feed thru the ADF ( Automatic Document Feeder ) there is a plastic piece with a plastic film. Check to see if #1 that plastic film is clean and #2 That the Film is not bent and created a crease which is the line that shows when try to print or scan using the ADF. Hope this helps
Dec 28, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Why is there still a line showing through middle of pages when scanning/printing via top document tray of toshiba e stuido 351c? I know who to clean glass area but not top tray.
Does this line appear when you try to print to the machine? Or when you make copies on the scan bed? If so, then you most likely have a mark on the drum unit. If not, then the **** glass that the document feeder uses is located to the left of the large glass surface, attempt to clean that and ensure that no mark or scuff marks are on the **** glass.
-David.
Nov 05, 2010 | Toshiba COPIERS E-STUDIO 3100C Copier
Line appears on scans and faxes
Do you use the document feeder when faxing and scanning? If so, the line is likely some paper dust, white-out, or other dirt on the thin piece of glass to the left of the main platen glass. Wipe that glass strip with a lint-free cloth, and if that doesn't work try using a little bit of alcohol.
If the line persists, or it occurs when you don't use the document feeder, it's probably dust somewhere in the optical portion of the unit, underneath the glass. If you want to take it apart, you can blow some compressed air around down there to scatter the dust or try wiping down the mirrors with a lint-free cloth.
May 05, 2010 | Brother Multi-Function Center MFC-240C...
Vertical lines about one half inch apart down center of the page when fed through the document feeder. No problem with fladbed copying or scanning.
If you open to document feeder and look at the glass when scanning via flatbed, just to the left will be a smaller piece of glass. That is the glass used when scanning through the feeder. Clean that glass as there is probably a couple of spots on it.
Jun 30, 2009 | HP LaserJet 3030 All-In-One Printer
A line appears down the length of the page on all copies, printing and scanning. How do I get rid of the line?
All you need to do is clean the top feeder which opens into two parts. make sure you clean the black rollers as well as the small strip of glass you will find when you open the second part of the top feeder . don't be afraid to pull open the top feeder it won't break
Jun 01, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Scanning documents
Has the machine got a doc feeder if so select twain scanning select doc feeder and the scan it will scan all pages in the feeder and then you should be able to save as one file.
Thanks J
Jan 24, 2008 | Sharp AL-1551 Laser Printer
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Samsung SCX-4725FN All-In-One Laser Printer Logo
169 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
