Question about Maytag Washing Machines
Maytag washer trouble
I have a Maytag Modelpav3240aww. The trouble; basket will not fill with water no matter how long water runs in. I think bad ejector pump, but wanted second opinion before ordering.
  • roland1011 Jun 26, 2008
    Thanks for the suggestion!
    however, the drain hose is higher than the basket. The washer has filled and drained correctly for months unitl now. Hot and cold water enter the basket fine it just will not fill, so I assume since I can find no leaks, its running through the drain pump up and out the drain hose?
    I'll check it out. thanks for the suggestion.
  • 413 Answers
If water is going into basket and just not filling up, make sure the end of the drain hose is terminated higher than the basket or the water will run out just as fast as it fills.
If no water coming in at all, the inlet/mixing valve may be bad.
Posted on Jun 26, 2008
  • Richard
    Richard Jun 26, 2008
    It sounds like a siphoning problem. If the hose is in the drain too far or there is an air tight seal around the hose to drain connection, water will siphon out.
Nf error code
If there is no water in the wash basket/tub you may have a bad water inlet valve. Try filling with a water mix Hot/Cold will the wash tub will fill and proceed.
If you need further troubleshooting support post back...........**** or Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Will not fill with water
HERE IS A TROUBLE CHART FOR YOU WASHER
The codes displayed will refer which direction to repair
DOWN
LOAD
THIS
WEBSITE
http://www.applianceaid.com/neptune8.html
May 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer keeps filling no matter the size I have
This sounds like a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water and signals the timer to start appropriate cycle. Make sure there is no damage to or obstructions in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | GE WSXH208A Front Load Washer
Maytag washer is leaking water. Looks as though
Check the water level switch. This is a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level, it activates the switch to turn off the water and signals the timer to start the appropriate cycle. Look for any obstructions in or damage to the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad switch. Sorry for your trouble and I sure hope this helped. Best wishes.
Aug 29, 2009 | Washing Machines
My daughters maytag has water leaking from the bottom.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 25, 2008 | Maytag PAV2300 Top Load Washer
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
Whirlpool super capacity Lsq9549lw0 has trouble spinning on its own.
If the washer does fine thru the agitation cycle (the washing), that means the motor is OK and the coupler is OK.  It would not agitate unless both are OK.  (and don't listen if anyone tells you the lid switch is bad -- machine would not fill & go thru wash cyle). The spin is another matter.  There is a separate tube for spinning the basket.  There is a drive  block at top of the tube (that sometimes fails)  and there is a separate cluch mechanism below, under the tub.  Those places is where you should look.
May 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag washing machine
The lid switch is bad on your washer. Either replace it or bypass it.
Oct 22, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
