Question about Canon PIXMA MP150 All-In-One InkJet Printer
Stuck up the ink waste is full.copy and scanning is cant do it now. my printer canon pixma mp145 is now on stuckup
  • nanawing4 Jun 26, 2008
    PIXMA MP130
    Genius:
  • 2,785 Answers
Plz visit the website
http://www.fixyourownprinter.com/forums/inkjet/50418#1
if the problem remains then you have to open the printer and locate the pad which is below the cartridge resting point, take out and wash and dried it put it back, if there is any pipe draining the waste ink that also should be washed.
Posted on Jun 28, 2008
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E3-3 = Paper jam
E4 = No ink
Direct Printing
E29 = EEPROM error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Message-the waste ink absorber is almost full on pixma MP130
That is usually Canon's sneaky way of telling you that is nearing time to buy new printer. Used on older machines without chips on cartriges. After "almost full" msg, usually follows "waste ink tank full" after which printer becomes unusable. Solution: Google "waste ink tank full" reset tool and run it, that should do the thing.
Oct 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
My Canon MP830 Printer will mot work. Alarm blinking and copy light blinking . How do i FIX? Dr.s' office...help!!
Canon MP750, MP760, MP780, MP830
The Unset mistake:
##341. Maintenance jet waste ink capacity full
##342. Cleaning absorption waste ink capacity full
##343. Ink detection waste ink capacity full
1. Include the printer.
2. Press button Menu , then Scan , Copy and once again Scan (entry in service mode, on дисплее will appear #1 SSSW)
3. The Arrow to choose 7. Printer test , press Ok .
4. The Arrow to choose 5. Ink abs capa , press Ok , install importance 0 .
5. Switch off the printer.
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E16 -E19 = Failed to scan head alignment sheet
E29 = EEPROM error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
CANON PIXMA ERROR 5800
The waste absorber is full ,Replace the pads
then if you still get the error,you can reset it by following the directions below.
(reset without replacing pads can cause damage)
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Jan 20, 2009 | Canon Pixma MP450 All-In-One InkJet...
MUMET
The main or platen waste ink absorber is full. Needs replacing and then the waste ink counter needs to be reset.
Service manual here:
http://www.tradebit.com/filedetail.php/4589462-canon-pixma-mp150-printer-service-manual
Nov 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber is almost full
Try this:
Resetting overflow error code for Printer Canon Pixma MP110
  1. Turn on the printer.
  2. Click Menu, and then Scan, Copy and Scan again. All - entered the service mode.
  3. Select Counter
  4. Click Copy - everything. Waste dropped to zero.
  5. Turn off the printer POWER button.
Good luck
Oct 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma mp110
Here this step by step to resetting waste ink counter printer Canon Pixma MP110
  1. You will include printer.
  2. press button Menu, then Scan, Copy and again Scan. All - entered into the service regime. 3. Select Counter.
  3. Press button Copy - all Pampers is discarded into zero.
  4. You will turn off printer by button POWER.
Aug 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma MP130
ink waste absorber is almost full, what should I do?
Jan 20, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
50 people viewed this question
old marine
old marine
Corne Viljoen
