Question about E-Machines eMachines Desktop PC
Emachines T2385 startup problem
My father recently bought a new computer and gave me his old Emachines T2385. He reformatted it before he gave it to me and now when it starts the Emachines screen pops up then it goes to a black screen with a small white line blinking in the top left of the screen. PheonixBios works but safe mode start up does not. I keep reading that they have PSU problems but i dont know too much about hardware issues. Any help would be appreciated. Thanks.
    Novelist:
    Scholar:
  • 141 Answers
Psu is a Power Supply issue but the black screen with a blinking white line is not.
The blinking white line can mean there is no instructions to tell the Computer to boot up. Which could be possibly the system battery (cmos) or Hard Drive.
I would narrow those 3 things down first.
Posted on Jul 01, 2008
Tip
My father-in-law broke his him a couple of years ago and his son bought and...
For this tutorial, I will be addressing a common problem experienced by many Samsung LCD, flat panel TV owners these day... "My Samsung TV keeps clicking for 20 minutes before it comes on" or "When I press the power button on my Samsung, nothing happens" or "When I turn my Samung TV on, there are white dots on the screen" or "When I turn my Samsung TV on, there are multi-color vertical lines on the screen"... there may be more, but these are the most common I know of. The models are numerous and seem to stretch from 08' - 09'. If you are having this issue and want to fix it yourself, read on.
TOOLS: #2 Philips Screwdriver, Wire Cutters, Soldering Iron, Desolder wick (with Rosin), Rosin Core Solder, Replacement parts (will be determined after disassembly).
The first thing we need to do is unplug the TV and move it to a good work location. You will need a soft place to place the TV, perhaps on a carpeted floor or on a blanket placed over the kitchen table ;).
Remove the 4 screw for the stand (RED area) and then pull the TV off the stand and place the TV face down on you soft work surface. Remove the 4 large screws (GREEN area) and the rear cover screws (YELLOW areas). Now remove the rear cover (screw location may vary depending on your exact model, so please make sure have them all out first).
Depending on your model, you may have a metal shield covering the boards. If not, you can skim ahead...
There are 2 major boards that will be front and center inside your TV. On the left we have the SMPS... this is where we will be working. So, we need to remove the shield cover to get to it.
Now that we have the cover off, we are able to take a closer look and locate the faulty parts. Have a look at the upper right corner of the SMPS (Switch Mode Power Supply). You will see a cable going over to the main board on the right... in this area you will find the problem.
The faulty parts are capacitors. The tops are generally swollen and often have blackened material exposed or leaking from their bulging tops.
You will need to identify the electrical value of the parts and locate suitable replacement parts (try Radio Shack). The values may be 1000uF 10v, or 2200uF 10v... whatever they may, you replacement part have an identical uF value but a higher v value... ex: Original, 1000uF 10v -> Replacement, 1000uF 16v. This will help prevent this problem from reoccurring.
Once you have the replacement parts, you are all set to install them. So, unplug the connection on the SMPS and remove the screws from the board. Heat up that soldering iron and remove the capacitors. Use the Desolder wick to clean up the pads, this will allow you to insert the new capacitors with ease. Be careful, these parts have polarity. This means that they need to be installed the same way you removed them... positive to positive and negative to negative. Each capacitor has a negative terminal, each mount location has a negative hole and it is indicated by the wide black band. After you insert each part, fold the legs over on the solder side of the board so that the part does not fall out and stays in position. Once you have all the parts reinstalled, solder them in. Make sure you make a clean electrical connection. Now use your wire cutters to trim the excess legs. Be sure to trim them close so that they don't touch any other electrical connections on the board.
Your SMPS is now fixed and ready to go... reinstall it into the TV and connect the wire harnesses back up to the SMPS. Double check your work. Are all the connectors back in place? Ok, now you should test your work before putting the whole TV back together. Prepare the AC cord, use an extension cord if needed. You will need to flip the TV up on to its top edge (upside down, screen facing you). Plug the AC cord into the TV and press the power button. Do you see the Video/Input indicator or RF snow on the screen? If so, well done! If not, unplug the TV and check you work.
You are now ready to reassemble the TV and return it to service.
** If you need some assistance in the soldering area, please have a look at my Tip "Soldering on the kitchen table, Class 101". I cover the actual soldering of a capacitor in more detail there.
If you have found this helpful, spread the word and/or leave me some feedback.
on Jun 22, 2010 | Televison & Video
EMachines 270 rebooting whenever new USB inserted
sounds like you have a short circuit try a diffferant usb port or a usb extension
Feb 11, 2012 | eMachines Computers & Internet
Recently bought an e-machine monitor as well as a new e-mcahine hard drive. we cannot figure out how to se the screen so that we can see the icons on the screen as well as the start button. HELP
Hi
Ok, I have to make assumptions here. Your old monitor and old hard drive went out at the same time? If this is the case then the problem is that the new hard drive has nothing on it. The manufacturer should have given you or sold you a set of recovery CD's. You'll need these to replace the NTFS partition and the operating system. Good luck
Mar 05, 2010 | E-Machines eMachines Monitor E15T4
I need disk number two of the restore disk for an emachine T2385. How can I get it?
have you tried the emachine's web site? ebay is a great place to look as well....
Feb 01, 2010 | E-Machines eMachines T3830 PC Desktop
I recently got a new computer and gave my old one to my cousin. I need the Office Home and Student Program on my new computer but won't let me activate it because the product key has already been used. My...
This depends on what version you have. If you bought the Home and Student version (3 Licence edition) then yes you can install it on more than one machine and use the same activation key on those three machines.
But If you haven't
Try phoning Microsoft and tell them that your porduct key doesn't work with your version but if that doesn't work you have to buy another version unfortunately.
Oct 15, 2009 | Microsoft Office Professional 2007 Full...
Emachine T2385 Won't Boot in Normal Mode past Windows XP Screen
The first thing I would check is your video card (usually driver) problem. Start windows in safemode with networking. If this problem has occured after updating the video card driver you may try rolling back the driver to a previous version, otherwise try
Once windows starts you'll want to go to the start menu and find and click run. In the text box enter the command "devmgmt.msc" and hit enter and the device manager should appear. Look for display adapters and left click the + and you should see your video card. Right click the video card and select properties from the drop down menu. Select thr driver tab. Now if the problem had occured after updating the driver, choose rollback the driver from the menu. If not try selecting the update driver option. After updating/rolling back the driver you'll want to try restarting in normal mode.
If it still won't start in normal mode you can try troubleshooting the video card under the general tab in properties, though to be honest I've found this rarely usefull but it might help you. Otherwise you'll want to make sure that your videocard is enabled in BIOS. A quick totorial of BIOS if needed http://www.tomshardware.com/reviews/bios-beginners,1126.html.
Otherwise it's likely a physical issue with the graphics card. Since you've tried reseating the card already it may be that the card is damaged and will need to be replaced.
Aug 08, 2009 | E-Machines Celeron 2.3GHz (rb-t2385)
Motherboard
you will need to get a m/b with the same dimensions as the old m/b .
sometimes when you replace the m/b the operating system will reconize it
If it doesn't then you will need to get a xp cd disk and errase the old operating system. then load the new o/s
Apr 20, 2008 | E-Machines eMachines Refurbished EMA...
Upgrade to a new motherboard?
I think there may be another issue.. It could be the power supply.. Have you tried a new one?
Have you installed any additional ram lately?
You can use the old XP software with a new motherboard, but it can be a pain in the **** to set-up if it is the OEM version of Windows, or a Recovery Disk that came with your machine..
What you could do, if you bought another motherboard, find someone with a Genuine Windows XP disk, and use your Product Key to install it..
Apr 12, 2008 | E-Machines eMachines Refurbished EMA...
How to program my new Keyboard cordless desktop S510
When I bought my s510 recently I couldn't use the function keys even with the software that came with the keyboard and mouse.
I had to actually download new logitech software for the s510 which allowed me to use the function/extra keys.
Navigate to:
http://www.logitech.com/index.cfm/keyboards/keyboard_mice_combos/devices/145&cl=US,EN
On the right hand side of the screen you will see 'Support Center' below it click 'Downloads,'
From there you can choose your OS w98 and language and download the software you need to get your keyboard working the way it should.
Oct 12, 2007 | Logitech Computers & Internet
E-Machines eMachines Desktop PC Logo
302 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
