Question about Biostar Computers & Internet
Motherboard Install a Motherboard 775Biostar via P4M800 chipset into a Emachine But It did not Go into window what is the problem.
    President:
  • 1,314 Answers
When you install an aftermarket motherboard, unless the chipset is the same then windows will not be able to load. You need to boot with a windows xp cd and do a repair install of windows or better yet a fresh install.
Posted on Jun 26, 2008
WHAT IS MAX CPU SUPORT OF P4M800-M7A ( above 2.6GH )
Select the "Start Menu."
Click to select "Control Panel." This will open a new window with several clickable options.
Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel
Click to select "System" from the new list of options
Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer.
Checking the Stock CPU Speed in Windows XP
Click the "Start Menu.
Right-click on "My Computer."
Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window.
Check the CPU rating as listed underneath the "Computer" heading.
Determining Real-Time CPU Speed
Go to CPU Speed Professional's website (see Resources) and download "CPU Speed Professional."
While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website.
Install the recently downloaded
" http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html "
file by double-clicking on it and following on-screen prompts to complete the automated install procedure.
Open CPU Speed Professional.
Click "Test Your Speed" on the main program interface.
A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension.
hope this helps
Oct 10, 2012 | Biostar P4M800-M7A Motherboard
My motherboard have Via chipset and also realtek codecs for the audio
first right click my computer then click properties then hardware then device manager scroll down to sound, audio and vedio controllers and see wether any is marked with yellow question mark or red X if its yellow question mark it means the driver is not installed properly if red X it means the device is disabled if red cross then right click the device and click enable if yellow question mark make sure you install the reight drivers after correcting this then click start setting control panel click sound and audio device then remove the tick mardk in the mute and click the volume to high and play some music
Dec 29, 2011 | Intel Biostar P4M800-M7A Socket LGA 775...
How to run windows 7 with ah3450 grafic card on kod p4x266 motherboard?
The MSI PM8m-V Motherboard has the Via P4M800 and Via VT8237 chipsets.
The website for MSI Does not list any drivers for Windows 7 for your motherboard. But since this is a common Via chipset you should be in luck.
A lot of driver support for VIA chips is built into Microsoft® Windows® 7 (32- and 64-bit).
VIA Hyperion Pro drivers
The VIA Hyperion Pro drivers contain all of the main platform drivers for VIA chipsets. The current release of these drivers is included in Windows 7, so at this time there is no need for a VIA Hyperion Pro package that supports Windows 7. However, as updates occur, a package will be released when needed.
You shouldn't need them, but to download the VIA Hyperion PRO Drivers click on the following link:
http://www.viaarena.com/Driver/VIA_HyperionPro_V524A.zip
The drivers for your video card the ASUS AH3450/HTP/256M Radeon HD 3450 AGP Card can be found here:
http://www.asus.com/Graphics_Cards/AGP_A_series/AH3450DI512MD2LP/#download
If you still need further drivers for this motherboard you can go to here:
http://www.via.com.tw/en/support/drivers.jsp
If you still have not found the drivers you need you can go to the MSI website and see if any of the Vista drivers will work for your system.
http://us.msi.com/product/mb/PM8M-V.html#/?div=Driver&os=Vista%2064
Aug 03, 2011 | MSI PM8M-V Motherboard
Chipset P4VM800 driver VIA 8237R
download from this link all driver avilable for your motherboard
Dec 04, 2010 | VIA Asus P5VDC-MX P4M800 PRO Chipset...
I want to downlad divers of P5VDC-MX VIA P4M800 RO CHIPSET FOR WINDOWS 07
there is a new disk on the market containg all windows7 drivers you can get one at a computer swap meet held on sundays at various locations
hope this helps
Aug 04, 2010 | VIA Asus P5VDC-MX P4M800 PRO Chipset...
USB 2.0 (Chipset VIA 8237) ECS P4M800-M7 Unknow Device
Hi, John
The USB 1.1 and USB 2.0 is a big issue regarding technology, the 1.1 has maximum speed of 12 megabits where as 2.0 has upto 480 Mbps. And all USB 2.0 devices are compatible with 1.1. Windows XP Home Edition and Windows XP Professional are both fully USB 2.0-compliant with the correct drivers.
So in your case it must work properly. But if the USB 2.0 from microsoft got currepted or badly updated by some thirdparty USB 2.0 driver then it will not work. I have been faced this problem. After doing some stuff I found that if I uninstall the USB drivers and reinstall it from microsoft driver then it works.
So, just go to the Device manager and un-install the USB drivers, then reboot the system to parmanently delete the removed driver. Then install the driver from Windows XP CD.
good luck
Thanks
Iqbal
Mar 25, 2008 | EliteGroup P4M800-M7 Motherboard
Computers & Internet Logo
93 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
