Question about Canon Office Equipment & Supplies
Canon Imageclass MF6500
Copier started making a rattling type sound - maybe sounded like paper was stuck - then started with streaking on front and back side. Changed toner - that didn't do anything.
  • Canon Expert
  • 287 Answers
Hello Barbara,
If i were a betting man I would say that indeed a piece of paper is lodged in the machine, in whats called the drum cleaning unit. This would cause the area where the image of any copies after the occurrence to have smeared/ streaked looks to them since the previous images could not be cleaned off properly. Your machine uses basically a "rubber squeegee" to remove previous images/toner from the drum so that the next image is clean and has no residual crud from the previous copy. If paper is between the cleaning blade (squeegee) and the drum then there will be yuck streched from the lead edge of the paper to the trail edge.And since the toner that should have been cleaned off and mechanically removed and deposited into the waste toner container, it has no place to go except to fall back into the paper path so that not only does the image area of the copy look bad but the back side will have **** on it as well since the toner that should have been cleaned off and carried away is falling down into the paper path and causing the backside to be contaminated as well. You may be able to lower the jam clearance lever to the vacuum transport and shine a flashlight UP and see the paper (I hope). If you do see it, carefully remove it as it will be well crammed into a tight area where several things could be damaged unless you tread lightly. THEN...... if you are successful, it begs the question as to why the paper went where it was not supposed to. Very thin paper or other unusual media can cause this. Or your "seperation corona " assembly may be failing or has failed. That's a whole different chapter of "HOW A COPIER WORKS 101". And God forbid the genesis of this problem was labels run thru the machine...... I wish you the best if luck and I wish I could be of more help.
Posted on Jul 03, 2008
Canon imageclass d340 making a loud clicking sound
It sounds like you may have sheared a gear tooth off the roller drive or the traversing mechanism. If you are getting copies just leave it alone.
Oct 12, 2016 | Canon imageCLASS D340 All-In-One Laser...
How to get copy count for Canon Imageclass MF6500?
Tell it to print a "self-test" page. Some of the printed output will be the copy-count.
Jul 22, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
CANON COPIER IMAGECLASS MF6500
It needs a new image processor, hope its still under warranty. The part retail is around $400.00 I just ordered one for someone today!
Jun 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Paper jams right before it exits copier
If the plate looks solid, then it's probably right where it should be. It sounds like a sort of ramp that feeds the paper into the fuser.
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Feb 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Code E808
This problem was solved by turning off the unit and unplugging the power overnight. The next morning it worked fine.
Jan 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Squeeking
The squeeking sound usually is in the fuser area
open the fuser roller area( clear paper jam the rollers are hot wait until it cools down get some spray silicone(similar to wd 40 with a plastic tube to reach small areas spray small amount on any e
xposed gears(plastic ) do not spray the fuser rollers
if you see nay other moving parts give them a light spray
turn back on and see if sound has stopped
If not try to determine when squeeking starts
then spary appropriate area
Dec 29, 2008 | Canon ImageClass D880 Copier
What is causing black streak
You should try changing the toner cartridges first. There may be something stuck in it causing the noise and streaking
Apr 14, 2008 | Canon imageCLASS D661 Digital Printer
484 people viewed this question
old marine
old marine
