I have a York Central airconditioning system in my house. This morning I put on the airconditioning at 19. The house temperature reads 25. It has not gone down at all from 25. I put my foot over the ducks on the florr but the air that is coming out is not cold at all.
    Novelist:
    Champion:
  • 230 Answers
Make sure that the outdoor unit is on. If it is on, then check to hear if both the big black compressor is running as well as the fan. If both are running then feel the fat copper pipe that comes out of the unit. If it is not cold and sweaty then your system is probably very low on refrigerant. If the line shows evidence of icing, it could still be a little low. Although icing can be the result of 4or 5 other problems as well.
Posted on Jun 26, 2008
No indicators working found fuse box which fuse?
When you are talking about "indicators" we could assuming that your are refer about signal lights. This work with "flashers" devices.
For 1996 Audi A4 2.8L SFI 6cyl the Flasher is located in front seating area, driver side, under dash, behind dash lower panel, mounted above driver side of steering column.
About generic fuses, open the driver side door. Remove panel on left side of dash. Fuse box is behind panel:
Fuse # / Description / Amps
1 / Heated washer jets / 5
2 / Turn signals flasher unit / 10
3 / Headlight washer, illumination of glove compartment, engine compartment, climate control, automatic transmission, instrument cluster / 5
4 / License plate light / 5
5 / Instrument cluster, seat heating, test connection for cruise control, bulb monitor for auto-check control, Automatic transmission display, switch lighting, mirror switches and actuators, airbag warning light, outside temperature indicator, Climate control / 10
6 / Central locking system / 5
7 / Anti-lock brake system / 10
8 / Vacant
9 / Mirror heating / 10
10 / Vacant
11 / Cruise control (automatic transmission) / 5
12 / On board diagnostic system / 10
13 / Brake lights / 10
14 / Interior lights, reading lights, anti-theft alarm system, vanity mirror / 10
15 / Instrument cluster, power windows, climate control, automatic transmission / 10
16 / Anti-lock brake system, Anti-Slip-Regulation / 5
17 / Heated door locks / 10
18 / High beam right / 10
19 / High beam left / 10
20 / Low beam right / 15
21 / Low beam left / 15
22 / Tail and side marker right / 5
23 / Tail and side marker left / 5
24 / Wiper and washer system / 25
25 / Blower for heating, climate control / 30
26 / Rear window defogger, mirror heating / 30
27 / Rear window wiper / 15
28 / Fuel pump / 15
29 / Engine timing / 20
30 / Sun roof / 20
31 / Tail lights, cruise control, automatic transmission / 15
32 / Engine timing / 20
33 / Cigarette lighter / 15
34 / Engine timing / 15
35 / Trailer receptacle / 30
36 / Fog lights / 15
37 / Radio / 20
38 / Luggage compartment light, central locking system / 15
39 / Emergency flasher / 15
40 / Horn / 25
41 / Anti-lock brake system / 25
42 / Vacant
43 / Vacant
44 / Seat heating / 30
Hope this helps (remember to rate and comme this free answeer).
Jun 16, 2011 | 1996 Audi A4
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
Good Morning, My nighthawk CO detector went off with a loud continuous alarm this morning while all were sleeping. I reset it and it is not alarming now. I pushed the peak button and it reads 19. The...
When a carbon monoxide detector sends an alarm, there is cause for concern. You mentioned that the other CO detector did not go off, but maybe it is too far away to monitor the carbon monoxide levels that was in this area.
The instructions in your manual would direct you to evacuate the house immediately and ventilate. Your next step is to get a professional to inspect what may have caused the carbon monoxide leak.
A reading of 19 indicates that there is carbon monoxide in that area of your house, unless your CO detector is not working properly. Your local fire department will give you the best advice for what action to take when a carbon monoxide detector sends an alarm.
Be safe, don't assume a carbon monoxide alarm is cause by a defective CO detector, have it inspected.
Jul 30, 2010 | Kidde Nighthawk Combo Gas/co Detector
How to replace a thermostat 1996 mazda mellinia
Thermostat - REMOVAL & INSTALLATION
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
1.5L, 1.6L, 1.8L (except K8) and 2.2L Engines
  1. Disconnect the negative battery cable. Drain the radiator to below the level of the thermostat.
  2. If necessary, remove the air cleaner assembly.
  3. If necessary, disconnect the coolant temperature switch at the thermostat housing.
  1. Remove the upper radiator hose.
  2. Remove the mounting nuts, thermostat housing, thermostat and gasket.
Do not pry the housing off.
To install:
  1. Clean the thermostat housing and the cylinder head mating surfaces.
  2. Insert the thermostat into the rear cylinder head housing with the jiggle pin at the top. The spring side of the thermostat should face the housing.
  3. Position a new gasket onto the studs with the seal print side facing the rear cylinder housing.
  4. Install the thermostat housing and 2 nuts. Tighten the nuts to 14-22 ft. lbs. (19-5 Nm).
  5. Install the upper radiator hose.
  6. If detached, connect the coolant temperature switch.
  7. If removed, install the air cleaner housing.
  8. Fill the cooling system. Connect the negative battery cable, start the engine and check for leaks. Check the coolant level and add coolant, as necessary.
2.0L Engine
See Figures 3, 4, 5, 6, 7, 8, 9 and 10
  2. Drain the engine coolant from the radiator to below the level of the thermostat.
  1. Disconnect the lower radiator hose from the engine.
  2. Remove the housing bolts, thermostat housing, thermostat and gasket.
To install:
  2. Make sure that the thermostat jiggle pin is aligned with the gasket projection.
  3. Install the thermostat to the housing. Align the gasket projection with the opening in the housing. The spring side of the thermostat should face into the housing.
  4. Install the thermostat housing cover and tighten both bolts to 14-19 ft. lbs. (19-25 Nm).
  5. Fill the cooling system. Connect the negative battery cable, start the engine and check for leaks. Check the coolant level and add coolant, as necessary.
Hope helps (remember rated this).
Jul 08, 2010 | 1996 Mazda Millenia
AC comes on, then shuts down before car is cooled. Compressor activates and blows cool air for about 15 seconds then shuts down.
Low on R134a, you need to have the system recharged. Try to stay away from the do it your self kit that most Auto Parts store carry.
Below are normal car AC pressure readings with 134A
Normal readings on high and low side with AC OFF (static pressure) – Depends on outside temperature, but normally is between 80-105 PSI
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI
Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better! Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
Thank you for using fixya and good luck.
http://www.freeautomechanic.com/airconditioning.html
Jun 12, 2010 | 1998 Cadillac Eldorado
Fuel Pump Fuse Number for a 1998 audi a4 2.8 quattro
Fuses: Fuse arrangement in fuse panel, behind instrument cluster, left
Fuse Arrangement In Fuse Panel 62624464
1 - Heated washer jets 5A 2 - Turn signals 10A 3 - Headlight washer (relay), illumination for glove
compartment, climate control, Automatic Transmission, instrument cluster 5A 4 - License plate light 5A 5 - Instrument cluster, seat heating, test connection
for cruise control, bulb monitor for auto-check display, Automatic Transmission display, switch
climate control 10A 6 - Central locking system 5A 7 - Anti-lock brake system (ABS) 10A 8 - Vacant 9 - Mirror heating 10A 10 - Vacant 11 - Cruise control (Automatic Transmission) 5A 12 - On board diagnostic system 10A 13 - Brake lights 10A 14 - Interior lights, reading lights, anti-theft alarm system, vanity mirror 10A 15 - Instrument cluster, power windows, climate control, automatic transmission 10A 16 - Anti-lock brake system (ABS), Anti-Slip Regulation (ASR) 5A 17 - Heated door locks 10A 18 - High-beam, right 10A 19 - High-beam, left 10A 20 - Low-beam, right 15A 21 - Low-beam, left 15A 22 - Side marker and tail light, right 5A 23 - Side marker and tail light, left 5A 24 - Wiper and washer system 25A 25 - Blower for heating, climate control 30A 26 - Rear window defogger, mirror heating 30A 27 - Rear window wiper 15A 28 - Fuel Pump 15A 29 - Engine timing 30A 30 - Sun roof 20A 31 - Tail lights, cruise control, automatic transmission 15A 32 - Engine timing 20A 33 - Cigarette lighter 15A 34 - Engine timing 15A 35 - Trailer recptacle 30A 36 - Fog lights 15A 37 - Radio 20A 38 - Luggage compartment light, central locking system 15A 39 - Emergency flasher system 15A 40 - Horn 25A 41 - Anti-lock brake system (ABS) 25A 42 - Vacant 43 - Vacant
Apr 05, 2010 | 1998 Audi A4
We have central heating and airconditioning both using the floor duct but the airconditioning has not worked since we have moved into the house but the previous owners said it did had trademen to look at...
make sure you don't have a flexible duct from the a/c to the vent. it can fill with water if drain is clogged ,check to see where drain runs too tape a wet dry shop vac to it and **** it out good and check for water built up in ducts and drain
Nov 09, 2009 | Heating & Cooling
My central ac system occasionally runs too long and the temperature gets way too cold. The digital thermostat reads that the temperature is too high so the ac still runs. This doesn't happen all the time...
I have seen this is many digital thermostats. The worst problems usually come from the touchscreen thermostats. I would suggest installing a new thermostat. Make sure that you read the instructions before you even remove the old one.
Jul 03, 2008 | Heating & Cooling
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
