Question about Sharp AR-BC260 Color Copier
Copy quality Copier copies great but when I print to it the blue comes out green. Any help is greatly appreciated.
  • Sharp Expert
  • 1,326 Answers
Did you try to print out single colors of M,C,Y, and Bk. You may find that one of your developer unit is mixed with another toner such as the Yellow has mixed with the Cyan. Or vice versa..
Posted on Jun 27, 2008
  • Chris Coughlin
    Chris Coughlin Jun 27, 2008
    Note you may have to calibrate your computer aswell
Faulty gradation print on RICOH AFICIO 3235C
check your driver, postscript? Or quality settings of the printer from the start menu
May 26, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Our printer will use the copier and scanner function fine but when we try to print some thing out it will not use any ink. we replaced both ink cartage black and color. All colors work when we copy or scan...
Do give the ink some time to come through, gravity will do the rest.
You could clean the ink heads to get the ink to come through quicker.
When printing the document, go through the settings and see if you see anything to do with the darkness of the print.
damnor01
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak 5100 printer has been great. Even though
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
Is the Demo printout giving the same result?
If so, you may need to replace the printhead. This is a very common problem with this model.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Canon np7130 copier
Most likely when you make a copy you don't see the light scanning the paper, you can try this with the lid open to make sure. the Sacnning lamp is blown, need to replace
Jul 14, 2008 | Canon NP 7130 Black and White Copier
Image runner 5020 will not print or copy
Hello Ernest T,
If the main thermistor which monitors the temperature of the fusing unit (that hot as hell area) is out of postion this problem can occur. The thermistor determines when the fusing area is hot enough to allow the copier to display"READY". If it is backed away from the fuser roller it cannot reliably read the temperature and it may cause the copier to display suspended because it reacting as if because of a long copy run it could not keep up the temp and so it "suspends" as it tries to ramp the temperature back up. Make sure the thermistor is touching the fuser roller.
Apr 16, 2008 | Canon imageRUNNER 5020 Copier
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Colors
Did you run a quality test print by pressing ink etc...?
It might be that you have no magenta anymore.
If you can see all the 4 colored blocks on the test sheet, firstly try to copy(!) a picture with pink colors and secondly run a pc print. If there is still no pink and you have it blue or green on the COPY one the scanner needs readjustment (from service personell). If you have trouble with the pc printing, too there might be
a defective ink cart holder which leaks and mingles the ink (you need a new ink cart holder then)
Jan 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
All in one printer
This seems to be a paper registration problem for the copy function only that is an HP thing Good old HP so innovative and so secretive none of us know whats going on most of the time. Two things to try. Take the stack of paper out of the feed tray and riffle so that it is slightly 'untidy' switch off the device , load the paper, switch on- see what happens. Next look at the software disk- there is usually a fully comprehensive reference manual on there [more than in the book]- check that out then come back.
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Sharp AR-BC260 Color Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
