Question about Canon Video Cameras
Canon GL2 mini DV Camcorder
No matter what DV Cassette tape I use, from least expensive to $8-10 tapes, I get some distortion of the image on 10-20% of the left side.  I would describe the distortion as "pixelation" for lack of a better adjective.  Small "blocks" appear, intermittently that distort the image.  I tried cleaning the heads with a Panasonic dry-type head cleaner but saw no change.  Any ideas?  Do I need to send the camera for repair?
Sam Kulp   shkulp@comcast.net
  • shkulp Jul 02, 2008
    It was the answer I was expecting but I guess I was hoping that a suggestion or two would be made concerning something I might be able to do that might eliminate the need to send it for repair.
  • Canon Master
  • 13,433 Answers
The problem has to be in the heads, they may need a more comprehensive cleaning or replacement.
Yes I would take it toa repair man to be checked.
Posted on Jun 26, 2008
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Well it seems that the recording head was damaged or in the stage that it was not functioning normally, the best way is to replace the recording head of the device..
  • micromaster
    micromaster Jun 26, 2008
    Check the tape path for
    contamination, especially the pinch roller and the capstan. The
    capstan should be a clean silver post. If there is buildup on the
    capstan, clean it off. Also check the pinch roller for any
    abnormalities. Check for any advance arms that are not working
    correctly. If these things check out and the problem still persists,
    then it's possible that the tape guideposts are out of adjustment.
    Readjust both guideposts until the problem goes away. Test
    adjustments by playing a variety of tapes with good recordings to test
    tracking ability. Readjust if necessary. If optimum adjustment
    is achieved, secure the adjustments to prevent drifting.
  • micromaster
    Hope this initial info/idea, helps you
    let us know..
My Canon GL2 keep telling me to eject tape
The problem that you are experiencing with your Canon GL2 camcorder is a common problem on your camcorder. Check out this video for more information.
Sincerely,
Sheryl Bahr
Oct 29, 2011 | Canon GL2 Mini DV Digital Camcorder
Canon MVX200i Mini DV Digital Camcorder: Remove the cassette
I got the same problem, does nobody has a solution. Please help!!
Eduard Mendlik
Jan 01, 2010 | Canon MVX200i Mini DV Digital Camcorder
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Remove Cassette Error
Sincerely,
Sheryl Bahr
Nov 13, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 still shot while recording on tape
there no way you can record a still photo while recording at mini dv tape cause the a tape and memory card switch rec mode
Aug 04, 2007 | Canon GL2 Mini DV Digital Camcorder
Video Cameras Logo
94 people viewed this question
Top Canon Video Cameras Experts
KellySD
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
