Cruise control switch works sporatically.
Faulty product. I install cruise control for 6 years. One of the cables are hooked into the throttle and the other in the vaccuum actuator, since it is electronically controlled actuator, the object itself might be losing it's contents or frankly worded, is taking a nose dive. works much like a brake booster does.
Is it a PID system? (Proportional integral derivative system)
or is it just standard proportional?
That will play a factor.
If you just have one of those cheesy controls (cruise controls), than replace it, obviously it wouldnt of cost much. if it is not, check the actuator and replace it! Replace the Fuse, brush it with wire brush, clean up all connections.
You should be ready to roll!
Good Luck.
The Cruise Red Control Power Light AND Green Engaged lights both come on, but the CC does not "take hold." If I open the hood and squeeze the big rubber bladder, the engine speeds up.
Where is the problem?
Jack
