Question about Sony Handycam DCR-PC100 Mini DV Digital Camcorder
Opening the tape compartment
When I try to open the tape compartment to change or put in a tape (with or without the power on), it makes all the right sounds, but the compartment doesn't move, let alone open. Any ideas? When I insert a tape and try to close the compartment there is a grinding noise and then I get an error message which prevents operation of the unit. PLEASE HELP ME.
  • 48 Answers
Something may be jammed in one of the hinges of the compartment door.
Posted on Jun 26, 2008
I can't open the compartment to put a tape in or get a tape out. Help
Attach the charged battery first then push the eject button
Mar 15, 2013 | iPhone Apps
Tape is stuck
First take out the battery. Then start unscrewing the outside panels to take it apart. Basically any screw you find, take off. The easiest way not to loose them is by sticking them into the side of a box. After you get the camera panels off, you should be able to carefully get inside and dislodge anything that may be in the way. Once you are able to dislodge the cord or whatever is causing this problem. Try inserting the battery and ejecting the tape. Let me know if you are having any trouble with this or have any other questions and I would be glad to help.
Good luck
May 20, 2008 | Sony Hi8 Hi-8 Tape
Manual eject option for trv320? No tape in it. Won't open so I can put one in.
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 06, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
I have a panasonic mini dv video recorder. After
close the tape compartment take the batery of press the power button on and holding the power press put the batery back and wait let me know
Jul 07, 2009 | Panasonic PV-GS150 Mini DV Digital...
Sony Handycam DCR-PC1E
Yeah ! Your problem is very simple. u can solve it on your own.
If you dont put the tape the comparment closes well and as soon as you pot the tape the compartment does not close , Right ?
The solution is there within ur hands itself.
If you want the compartment to be closed, then simply dont put the tape inside. let it be outside itself. U see, its so easy !
Aug 08, 2008 | Sony Handycam DCR-HC90 Mini DV Digital...
Canon ZR100 cassette compartment won't open
Usually a chime happens when you open the plastic cover just before it opens. If you plug it into the electrical outlet does it eject that way?
Jul 06, 2008 | Canon ZR100 Mini DV Digital Camcorder
Tape Eject Problem
I have the same camera and it just did the same thing.  Can't open it and its jammed.  Hope you find an answer, but my answer was to go out and buy a JVC 850 at Circuit City for 200 bucks.
May 31, 2008 | Video Cameras
I have the same issue. The Handycam can sit on a table without anyone touching it and it acts like it is haunted. The tape sounds like it moves on its own and sometimes it won't let me playback or record. I repair shop I called told me it sounds like a $7 switch is broken, but it will cost $150 in labor to repair the switch.
Jan 08, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Tape won't come out!
I had the exact same problem, and just by dumb luck, I managed to get the tape compartment to pop open after trying hundreds of things. Maybe this will work for you too...who knows??? What I did was to first remove the battery and AC power to "reset" the camera (I guess). I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VIOLA!!! Like I said, it may be dumb luck, but I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism...dunno???? BTW, when I was having the problem, the mechanism would "click" 3 or 4 times while trying to move the tape out. Good luck!!! I hope this helps someone!
Jul 24, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Sony Handycam DCR-PC100 Mini DV Digital Camcorder Logo
149 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
