Question about KitchenAid KESC307 Electric Kitchen Range
Cannot shut off the kitchen aid stove with the "Off" button, model # KESA907PSS01
  • 2 more comments
  • arfung Jul 28, 2008
    "Off" button does not shut the over off on my kitchen aid stove. I have to set the cook timer to 1 minute duration and hit start in order for it to shut off. This is a safety issue!
  • rjs3 Sep 20, 2008
    I have the same oven and the same problem. I did keep calling and Kitchenaid responsed that this was a safety issue and I needs TO CALL BACK!!!!!
  • Anonymous Sep 21, 2008
    Gas range will not turn off.  We as well had to turn the breaker off.
  • daphnine Dec 12, 2008
    I have the same problem. What do we do to fix?
  • 25 Answers
I had the same problem with mine.. i overboiled some water and it leaked down the front onto my panel (inside).. i had to replace the whole thing.. (i did it so i added a silicone bead inside so water cannot get to that same panel area)..
3 years and it still works..
replacement panel is about 120.00 CAD
Posted on Jul 22, 2009
I have kitchen aid glass stove top stove. Had to replace wiring and broke to glass when putting it back in. How do i replace it now with out breaking the new one?
The following link will give you some advice on how to replace a glass cook top for a kitchen range:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
If you have any questions about this repair, please post back and let me know. Please include your MODEL NUMBER when submitting questions. I hope this helps you.
Mar 02, 2010 | Kitchen Ranges
KGCS1340P stove top -- I need burner drip pans. Source for parts, please?
I'll be glad to sell you one. I have the same model and am ready to replace it with a new cooktop. I have the same KGCS1340P but can't find part under the knob.
May 18, 2009 | KitchenAid Kitchen Ranges
Kitchen aid stove oven shutting off reading error f2:E5 what happened?
Electronic range clock failure. You will need to replace this part. It is located where your keypad is. You will need to get behind it and pull the part out and replace it with the exact kind from repairclinic.com
Feb 21, 2009 | KitchenAid KESC307 Electric Kitchen Range
Control Lock light is on and nothing works on my stovetop
Hi. Research your stovetop on the kitchenaid website. You should be able to download a user manual for your model. The manual should tell you how to reset the lock. If a manual is not available, try disconnecting the power supply to the stove. This might clear the memory of the stove. Good luck. ricardok45
Feb 02, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid stove top
whats the model?
Jul 22, 2008 | Cooktops
Cooktop not responding . . .
whats the model num???will help looking up a wire diagram or manual. look closely at all the control buttons for one thats marked with a little pic of a lock. press and hold it for 3-5 secs . . if controls locked there should be a lock lit in the display
Mar 07, 2008 | Kitchen Ranges
Kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Dec 03, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
379 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
