Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp lcd LC26PX5M
Modelno.LC26PX5M no audio out when input anything cable,audio video input picture is complet but no audio.audio output amplifier is ok speker also ok.please regard soon as possible.
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Posted on Feb 21, 2008
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
I have a Sharp Aquos. A video cable is connected to interface EXT-4. Video is working fine. Which audio interface can |I use to get audio too and what do I have to set in the TV menu?
There should be RCA type audio input connections near the ext-4 video cable. One red and one white. If you connect these cables you won't have to do anything in the menu.
Aug 30, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
I have a 42in hannspree that i am trying to hook my surround sound. What do I do?
Run an optical cable from the back of the TV to the input on you audio/video receiver amplifier, then access the A/V receiver's menu and navigate to optical inputs, assign the one you connect the cable to in the previous step, to TV or Sat function (the input or source on your remote), verify it and you are done.
If no optical output on the back of the TV, then use the RCA audio output, and just connect it to any audio input on the back of the A/V receiver, and use that specific input as a source when listening to the surround.
HDalacarte.com guy, audio/video/computer technician for over 30 years
May 26, 2011 | Hannspree ST42DMSB 42 in. LCD TV
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
How to hook up sharp dolby surround pro-logic model- HTDP3000 to my RCA tv I need to know exactly how to connect the wires from sharp surround sound to my RCA high definition tv
The source of your program will determine how you hook things up, and if you want to (if it's possible) route the video through the Sharp as well. Some systems have video switching, so you can run all sources through the system, and have a single video cable running to the TV.
If you are using a DVD player, typical Pro-Logic requires a red/white RCA cable from the DVD player to the amplifier unit. The video cable, either a 4-pin S-Video or a yellow composite cable, will run to the amplifier unit for switching purposes, or ditect to an input on the TV.
You can also run red/white RCAs fron the HDTV to an input on the Sharp. You likely have to set the TVs audio output to "fixed" or "external", which will disable the TVs speakers, while putting out sound to the Sharp.
Jan 06, 2011 | Sharp HT-DP3000 System
I spent the last hour on the phone with tech support for my local cable company. after the duration, we came to the conclusion that there was in fact, not a space for the red, yellow and white chords....
Without seeing anything, the yellow=video, the red and white=audio. The yellow/video "output" of the cable box goes to the yellow/video "input" of the TV. The red and white are the audio that go from audio "output" of the cable box to the audio "input"of the TV. I don't know what the Cable company was telling you???? The cables are "RCA" and give you the worst clarity for a picture. If you cable box has three output ports colored Red, Green, and Blue ("Component') and you TV has the same three as inputs, that will make your picture much better. If you can hook it up with the component jacks, you will still need the audio RCA (red and white) between the two units. I hope this helps.
Oct 27, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have a white female rca and a red female rca which means right and left speakers hanging out of the back of my car audio cassette player. i can't anything out of them, nor can i get anything to go...
Hello joebobstgeor,
I wasn't able to lookup a manual for the Sharp GB960. In fact, manuals for any Sharp car audio product was woefully absent.
Try connecting the cables to the input of an amplifier. Female RCA jacks are used for low-level (preamplifier) outputs for subwoofers, sound processors, and additional amps. The impedance of the output is typically in the 20-25Kohm range and would not produce any sound in speakers or even low impedance headphones.
It's also possible that the RCA cables are an "AUX" input to the receiver and not an output. Although many of the mobile audio manufacturers are now using front-mounted phone mini-jacks as "AUX" inputs, some still have rear mounted RCA's.
Hope this helps.
May 18, 2009 | Sharp Car Audio & Video
Hook up speakers to 32 inch lcd hdtv
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
May 16, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
HELP WITH CNECTION
Only if you've got an HDMI output on your computer. Some computers with higher quality video cards, or just newer ones will have a DVI output for a monitor. You can get a DVI to HDMI cable that will then be able to connect the two.
As others have said, if you have a video card with DVI output, you can get the video to the TV using a DVI to HDMI cable.
But no one mentioned anything about audio. DVI can not carry audio, so you'll need to send audio from the computer to the TV (or receiver). Some TVs have audio inputs associated to one (or more) HDMI ports for use with devices that have DVI, but not HDMI. My Sharp LCD has two HDMI ports, one with separate audio inputs, one without.
Sep 27, 2008 | Computers & Internet
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
41 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
