Question about Fisher Paykel EcoSmart GWL15
My washing machine stops mid cycle
My Fisher and Paykel EcoSmart washing machine stops the wash cycle after running for about 10 minutes. Each time I need to push "start" to resume the cycle. Then it continues to completion. Any idea what's going on?
  • 2 more comments
  • TRF1 Jul 25, 2008
    We are having the same problem - HELP!
  • jjbolden61 Jul 31, 2008
    My washer runs through the wash cyle till it gets to the final spin and stops. It just sits and beeps at me. I have rearranged the clothes, in case
    the load is not balanced, but it wont move forward. I have unloaded all the
    clothes and removed all the water and unplugged the machine and tried it
    again, and the same thing happened! jb
  • Anonymous Mar 21, 2014
    My Fisher & Paykel 6kg front load washing machine stopped mid cycle and I cannot work out how to stop it and reset it to get the clothes out
  • Anonymous Mar 30, 2014
    wash cycle starts then stop shortly into cycle
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
Issue where washer stops and water won't drain might mean something is in drain area.
look at my issue "eco smart won't drain, smells hot" and see about the sock. I found one of my husband's socks so far down in the tub bottom that I couldn't see it when I looked between plastic outer liner and wash tub. Had to remove black motor/white housing on bottom of machine--which i had to replace cause it burned out. That is when I saw the sock and pulled it out through a quarter-sized hole.
Posted on Oct 21, 2008
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel washing machine
Without being smart...buy a new machine. It sounds as though the timer is dying...therefore slowing down...therefore extending cycle times. If that's the case, a new timer will cost about half the cost of a new machine.
May 06, 2012 | Fisher and Paykel Washing Machines
The washer wont drain
Check clear filter //pump
Sep 29, 2009 | Fisher Paykel EcoSmart GWL15
Stops mid cycle
It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
Jun 12, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel ecosmart purchased 3-4 years ago.
I too am having this problem.  I am checking out if anyone has a solution.  Somewhere someone said to change the "Fill switch"  I don't know what that is or where it is.  Does this help?  If you have found anything let me know. monica.roberts@usa.com
May 23, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & Paykal washing machine, Mod:GHL10US
if you want to find out for sure post your email here and i will send you the service manual
Jan 15, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Help!!!!!
Check to see if you have a blocked filter. Regards Engineer
Jul 28, 2007 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
376 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
