Question about Whirlpool Refrigerators
Strip between refrigerator and freezer (side by side model) is not warm but hot. What is likely cause and is it repairable
    President:
  • 1,462 Answers
It should be warm - it is designed like that to stop condensation. not a fault
Posted on Jun 26, 2008
I have a Kitchen Aide KSRS25ILBT02 Side by Side and the metal strip (mullion?) between the freezer and the refrigerator is hot to the touch. Hot enough to cause a burn if you leave your finger on it for...
You have a defective defrosting strip. A hearing element that warms the side of the fridge to melt ice that collects. Your fridge is dangerous to operate. You have a possible short in the defrost system that can electrocute you. You should unplug immediately. I am SERIOUS.
Aug 03, 2014 | KitchenAid Refrigerators
My Kenmore Elite side by side refrigerator was blowing very warm air out of the grate at the bottom and the temp on the display in the fridge is rising. I also noticed the on the surface of the divider...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 11, 2011 | Kenmore Side by Side Refrigerator
Inside refrigerator strip between the freezer and refrigerator
The condenser fan motor at the back near the compressor is either dirty or not running at proper speeds. Clean the coils for air flow over compressor and if the fan is not running replace the fan.
Jul 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Defrost heater staying on causing rubber strip on doors to get extremely hot
hmmm... This would cause a freezer meltdown and spoiling of your food. Are you talking about the heating element behind the freezer panel ? There should be a safety to shut off the heater - there is another type of heating element to prevent moisture during hot humid summer days, controled by an "energy saver" switch - on older refrigerators - when this is on it is normal for the base between the freezer and fridge to be warm - but if it is the defrost element in the freezer, this is not normal at all - usually it should say on for around 20-25 mins or as needed - in which case you have a defrost timer / defrost components problems and need to get it serviced A.S.A.P.
Sep 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The facing of the frame between the fridge and freezer is very hot (right where the seal makes contact). Is the defrost not switching off? Is there a timer or thermostat that may be bad? If so, hoe do I...
Model and brand is always helpful when requesting information.
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a refrigeration problem.
Aug 22, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Ice smells and tastes baaaad, water smells and tastes baad!!!! I changed the line and it still stinks...please help...
Check all of this;
  • Remove spoiled food
  • Clean refrigerator interior with a solution of hot water and baking soda
  • Clean the door seals
  • Remove breaker strips and check for wet insulation
To remove the breaker strips it is important to bring them up to room temperature first. If they are too cold they will be brittle and may crack. To warm the strips you can open the freezer and allow it to come up to room temperature (wait 2 to 4 hours) or you can soak a towel in warm water and hold it against the strips to warm them.
Good luck:
Don't forget to rate;
Jul 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Both Freezer door and cooling door and a metal strip were hot
That is a good thing. you want that to happen what it does is it avoids condensation to form around the doors
Apr 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Have 16 yr old Kenmore model 106.9537622. The heater strip at the center divider between freezer and frig gets real hot for a period of time everyday and causing frig and freezer to be too warm. The...
if this is a side by side refrigerator, then the space between the doors is not heated by an electric heater. it is heated by part of the condensing coil. so the excess heat is probably generated by a loss of adequate airflow under the machine. which would explain the temperature change in the refrigerator.
  • clean the coils under the machine and make sure the fan is working.
  • make sure the airflow is not obstructed in any way.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | Refrigerators
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
