Question about GE Dryers
There is felt string like padding that has come loose from between the dryer drum and the dryer itself.
Thanks for the reply. I ordered a new felt drum seal and will replace it upon its arrival. Then the problem will be fixed. dee
Posted on Jun 28, 2008
NBXR453EVOWW dryer squeeks
The rear drum bearings could be going out, and believe it not, on some rare occasions the motor itself could make a chirping sound.
Jun 21, 2012 | Hotpoint Dryers
My Frigidaire front load dryer is ruining my clothes. I can only guess loose straps, strings... get caught on lint trap on door and with the continually spinning o the drum, they eventually break. I...
If you take front of dryer off, there is a half moon shaped piece of felt on top of door opening that most likely has worn and leaves a gap between drum and where that felt is. Replace that for right drum fit.
Sep 11, 2017 | Dryers
How to repair stainless steel on a dryer drum
For my Frigidaire manufactured Kenmore dryer, the stainless steel drum is part ordinary painted steel (front flange). That flange is part of the suspension for the drum. The flange rides on a nylon wear pad above the door. On both sides of the pad, there is a felt that is glued to the dryer front panel to act as a seal. What happens is that the paint on the ordinary steel flange rubs through and rusts, staining clothes during the drying cycle. I have to replace the nylon pad and felts every few years to combat the rusting issue. The felt and nylong pad assembly is glued to the cabinet flange using heat resistant adhesive.
Feb 25, 2012 | Dryers
My dryer eats my clothes by twisting them up between the drum and door. is there an update to fix this?
the front of the drum rides on a felt pad. as the pad wears down it creates a gap for the clothes to get caught in. you just need to replace this felt. sometimes called front bearing sometimes called felt seal.
Jun 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I've changed the drive belt, but it seems that the...
If the drum being pushed forward makes the problem better, I would say your felt pads under the drum which the drum rides on are either worn down the metal or loose.You need to remove the front casing of your dryer and inspect these felt pads. If they are loose tighten them up and if they are worn they need to be replaced. When you have your dryer apart you may also want to try to move the rear of the drum to the left and to the right and see if the back of the drum is loose as this means your bearings are loose and may need replacement. To fix this problem however the top of your dryer will have to be removed to take the drum out (many times the top will tilt back on hinges) because the bearings are on the back of the drum.
May 12, 2010 | Dryers
Dryer drum is scraping something and black deposits are turning up on our clothes
Well there are two parts to the drum, there is the bearing in the back and the felt pads in the front which the drum rides on. There is also a belt, but if something is scraping it would not be that. Is sounds as though the cover on the felts has worn off and your getting felt material on your clothes, so those need to be replaced. You need to get the proper felts for your dryer than you need to look for any screws on your dryer casing that will allow you to remove the casing and get to the drum, as the pads are underneath the drum. (Note: Inside the door there may be screws on the underside of the upper deck, and the deck should tilt backward on hinges)
May 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Noisy when drum turns, felt pad is broken
more than likely,the felt pad itself is the problem and needs replaced...degree of difficulty on a 1-10 scale would be 6
Mar 06, 2010 | Hotpoint Dryers
Felt belt, son pulled out from the front,inside of machine
the felt is attached to the front bulkhead to your dryer. in some cases, the dryer drum itself runs on that felt. other times, it is sitting just above the drum. if your drum actually rides on the felt, you will need to get it fixed because the glides will get worn and the drum will start to scrape on the front bulkhead. if you open the door and take out the 4 screws ( 2 on either side ) then you will be able to take off the front panel. once that is off, there is a 3/8 nut screw on either side ( on the top ) that hold the lid in place. remove those 2 screws and you can lift the top of the dryer. this will give you a better view of your dryer and the extent of the issue. Joe
Nov 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Hot point dryer
the drum has dropped
the drum is suspended on felt pads to seal the drum edges, nylon guides at the front, and rubber tyred thrust rollers to withstand the torque of the motor and belt at the rear.
the usual cause is the rollers have failed, common fault, easy fix, cheap too
good rollers look like this
1ac2db2.jpg worn rollers like this
try not to run the dryer till the rollers are replaced, the extra strain will break the belt,
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
  1. drum motor felts and bearings are now accessible.
  2. pull tensioner fully agains spring
  3. remove belt from motor pulley
  4. lift drum and withdraw fully forwards
  5. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear
reassemble.
  1. loop belt loosely around drum at wear marks from prior installation
  2. reinsert drum onto rollers bearings slides felts as installed.
  3. loop belt around motor pulley
  4. pull tensioner pulley against spring to end of its travel
  5. loop belt around tensioner pulley
  6. relax tensioner pulley to tighten belt
  7. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Jun 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
56 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
