Question about Samsung Televison & Video
HDTV Model # HCN473WX/XAC picture projected as several overlapping, different colored images
  • aemurphy80 Jun 26, 2008
    i was looking around to see if other people had similar problems and a lot of the responses mentioned burned out convergance ICs - is that what the STK392-040's are??
    i looked at the current convergance settings and it seems to be only the red tones that are off, but adjusting the convergnce does not help.
  • 63 Answers
I dont know this exact model as I'm in the UK but try the problem sounds like a convergence issue.
Look in the manual for how to adjust the convergence. It's a little tricky and time consuming but you should be able to do it.
If you need anymore help let me know and I'll try to find a manual for it.
Andy
Posted on Jun 26, 2008
  • Andrew Real Jun 26, 2008
    Do any of the colours move when you try to adjust the convergence?
    Master:
  • 788 Answers
This sounds like a convergence problem, hopefully the convergence circuitry is ok and it just needs to be adjusted. I will look up your manual and try to get you instructions on adjusting the convergence.
  • Dean Joly
    Dean Joly Jun 26, 2008
    Your manual is located here: http://downloadcenter.samsung.com/conten...
    On page 3.3 there is a procedure for running the perfect focus adjustment, start there. Here are the steps:
    1) Press the Menu button. Press the CH button to select “Function”, then press the VOL + button.
    2) Press the CH button to select “Convergence”, then press the VOL + button.
    3) Press the CH button to select “Perfect Focus”, then press the VOL + button. Perform Perfect Focus in the following sequence: Green,Red, Blue. Press Menu button to exit.
    If this still doesn't work then try the manual convergence as seen on pages 3.4 and 3.5 of the manual.
    Go to the convergence menu the same was as described above, then:
    1) While “Red” is highlighted, press the VOL + button: A crosshair pattern will appear on the screen. After moving the cursor to the position you want to adjust using the number buttons 2(up), 4(left), 6(right), 8(down) on the remote control, adjust Red Convergence by pressing the VOL +/ VOL -/CH up /CH down buttons.
    2) If a horizontal red line is visible, use CH up and CH down buttons to move the line so that it is superimposed on the horizontal center-line (i.e., make a single horizontal line that is as white as possible.)
    3) If a vertical red line is visible, use the VOL + and VOL - buttons to move the line so that it is superimposed on the vertical-center line (i.e., make a single vertical line that is as white as possible.)
    4) For ‘Blue’ adjustment, do the same as the above.
    After the red convergence is correctly adjusted, press Menu to exit all the menus.
    If this still doesn't resolve your issue then the convergence ICs are faulty. They can be replaced the part numbers are STK392 and STK040.
  • 2,326 Answers
It looks like your TV has developed a failure due to a hardware malfunction. The hardware that failed are mark STK392-040 and will need to be replace to restore the proper functionality of your TV.
Do you have any experience with hand tools such as soldering iron and or using a multimeter?
If you do, this repair can be a DIY; keeping in mind that you will have to disconnect the TV from the AC power before start working around the circuitry. I would suggest to leave unplug for about a day just to let the capacitors discharge the energy store in them.
  • Jaime Hernandez Jun 26, 2008
    If the magic focus does not work then the STK392-040's are defective. I would also suggest to check for open resistors nearby the STK392-040's, specially the low value ones.
Picture has a yellolw haze
The answer here is based on the model number indicated here(if different let me know).
This is a projection set with 3 picture tubes.
With set on and color all the way down (off) stand back and examine the screen= do you have a black and white image or a yellow image?
Apr 19, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Picture has a yellow haze
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
Projection image
your convergence ic's need replacing
Jun 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have picture but color overlaps and is not sharp or crisp.
depending onwhat board you replace you may have to copy the light engine data to the chassis to sync the color wheel.
Dec 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Multiple pictures
Try www.magnavoxhelp.com - They have a fix listed on their site.
Jun 01, 2008 | Philips 55PP9363 55" Rear Projection...
Red and Green picture with ghost images
sounds like the high voltage transformer arc or one of the picture tubes arc causing the convergance ic to go bad
you can try to replace the IC heres a site to help:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
but you still may have a arcing problem.
Dec 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Samsung HCN473WX
you may need to do convergence to align the colors up.
the only thing other than the ic that need to be replaced are resisters and if the resisters are bad you would not be able to move one of the colors, and blow out the ic you just installed.
Nov 04, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
126 people viewed this question
Henry  Thomas
Henry Thomas
