Question about Miele 24 in. G665 Built-in Dishwasher
Miele g665 sc
The drain pump on my d/w is running all the time and will not stop no matter what position the timer/settings knob is in. Any body got any ideas?
  • superfred Jun 26, 2008
    Just had the thing apart and the bottom tray was full of water so the anti burst/flood device kicked in. I can't seem to see any way for the water to be pumped out and am curious as to why the drain pump runs when it doesn't appear to be able to pump the lower tray out.
  • Anonymous Feb 24, 2009
    I have a Miele G894 sc with the same problem, drain pump wont shut off, and machine wont run. took off bottom pan and full of water activating the float switch. I noticed there is a plastic pipe that seems to be a drain into the pan. Dont know where it is coming from. Any ideas? Did you fix yours?
I had the same problem...took off the bottom tray, put the dishwasher on two chairs, started off a cycle & spotted a leak which i fixed with bathroom sealant.Then refitted the bottom tray. Recon the repair cost me about 2p!!
Posted on Jan 20, 2010
  • 1,462 Answers
I think its daft as well but nearly all dishwashers have this feature. you have a leak somewhere to cause this
Posted on Jun 26, 2008
Miele dishwasher drain blocked. f11 message. Help!!
Hey there - if you have not read any of the post on here - the pump could be serviced from inside the machine, empty trays out, revoe the steel mesh on bottom with a lock lever where the drains is, under here you will see a steel spring like clip, move & pull the housing under it, then the pump impellar is there - just clean it out carefully - assemble or close door run a drain for 2-3 secs, assemble . should be good to go.,
May 25, 2011 | Miele 24 in. G665 Built-in Dishwasher
My miele G665 SC is not draining all the waste water away at the end of the cycle, i've taken the filter part out of the bottom and it's all clear and even run a cycle without it, is there another filter...
Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jul 02, 2010 | Miele 24 in. G665 Built-in Dishwasher
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
I need a new timer for my miele g 665 dishwasher, were can i buy it?
spares are only available through Miele spare parts or their registered service agents who will probably then source the part from Miele spare parts anyway.
Dec 15, 2009 | Miele 24 in. G665 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele dishwasher not working
your timer is shorted out. probably caused by a cockroch
Aug 06, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Jul 21, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele g665 dishwasher
Wow... one week is a long time. Those dishes has to be very clean or at least worn out by now.
From what you are discribing, it appears you have a timer control module that is malfunctioning. You might try that first. If that still doesn't do the trick, check the fill valve sensor/seliniod
Jun 09, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele g665
where is the water coming out at? Are you using the proper detergent? if the machine is too full of water and a fill float valve is stuck open, water sometimes overflows.
Check to make sure the fill valve is working, then check to make sure pump is operating. (you will know when you turn the machine onto the rinse cycle.)
Mar 17, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele 24 in. G665 Built-in Dishwasher Logo
1,238 people viewed this question
Top Miele Dishwashers Experts
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
