Computers & Internet Logo
Anonymous Posted on Dec 02, 2010
I put a disc from my printer into CD area and I can't get the drawer to pop open. I also attempted to eject it through the computer. HELP!
Norman Worley
Level 3:
Genius:
  • Master 1,273 Answers
  • Posted on Dec 02, 2010
Norman Worley
Master
Level 3:
Genius:
Answers
1273
Questions
0
Helped
325126
Points
3473
Look at the front of the CD somewhere on the front, there is a small hole. Straighten out a paper clip and insert into that small hole and push in gently. This should release the CD tray mechanically. Almost all of the computer installed CDs have this feature.
Testimonial: "Perfect advise ----- it worked!"
I hit the eject button and the drawer opened, but my disc was not there
It will take the removal of the CD drive and opening the case to dislodce the CD from the spindle.
2helpful
2answers
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim [email protected]
Manually eject cd
If you can't eject using the button on the CD drive, you can use Windows File Explorer to locate the icon for the CD you have in the drive. Expand the area for Computer. You should see the CD drive listed below the Computer icon where all the devices are listed. Right-click on the CD icon to get the pop-up menu. Then left-click on the option that says eject and the CD drawer should open.
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
HP Z1 WORKSTATION WON'T EJECT CD
Make sure the computer is turned on then Take a Paper Clip (Gem Clip) and straighten it out then kneel in front of the desktop facing the cd drawer. Look closely at the drawer and you will see tiny hole where you will insert the paper clip (Gem Clip) and at the same time Press the Button on the cd drawer while applying pressure by pushing the paper clip (Gem Clip). The drawer will pop open. Don't worry about breaking something, that's why that tiny hole is there.
4answers
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
1helpful
2answers
How to insert a cd in a laptop I have never operated a laptop befoe.Plz help .
go to my computer then you can see your disc drive there,
right click it then click eject, then the disc tray will pop out then put your disc and push the tray,
pls rate if this thing helps
4helpful
4answers
I have got a disc stuck in my acer L100,is there anyway to get it out.
there will be a small hole below the cd drawer, insert a straightened paperclip and drawer will open slightly pull all way open, remove disc and use button to close again.
If it happens again it could be a sign of fault in cd unit.
Cd drawer
there is a little pin hole on the front of the cd/dvd draw, insert a pin or sharp object and it will eject.
Can't get disc out of tower
Restart the computer, and when computer is starting up keep pressing many times the eject button until disk pops out.
Do this a couple of times
If this does not work you will need to remove the CD/DVD unit and stick a paperclip on the CD eject hole, in the front side of the CD/DVD drive.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
