Question about Xerox Phaser 8550DX Laser Printer
Xerox Phaser 8550DX
Is there a memory upgrade available for this machine? When I work on large documents with multiple images I have to split printing into 2 or more stages otherwise it gets stuck and refuses to print.
    President:
  • 2,072 Answers
There should be. You can take pop the board out of the back with 2 thumb screws and see if the expansion slot is open/
Posted on Jun 26, 2008
Memmory full massage
Solution : Print Received Faxes or Transmit Documents in the Transmission Line The machine can no longer receive any new fax transmissions because the memory is full. Clear the memory by printing all received documents, or by transmitting or deleting the documents in the transmission line.
Phaser 3100MFP Support Drivers
Apr 07, 2014 | Xerox Phaser 3100MFP/S Laser Printer
I have hte xerox phaser 3100mfp & when I try to scan some paper to media device it says "memory full press <stop>" what should I do? P.S. I've tried to restart the device but...
13 Memory full The machine memory is full (there are too many documents that have been received but not yet printed, or waiting to be transmitted).
Print the received documents.
Delete or transmit in immediate mode the documents waiting to be transmitted.
14 Memory full Received document memory saturated.
Jul 13, 2011 | Xerox Phaser 3100MFP/S Laser Printer
How do I check the history of the number of prints on my Xerox Phaser 8550?
connect to network
type ip address on any machine in the same network
in the webinterface you can see the all details
Oct 27, 2009 | Xerox Phaser 8550DX Laser Printer
PCL5 OUT OF MEMORY Phaser 8860
After reading some similar stories, I simply restarted the Xerox Phaser printer via the menu on the physical printer. I theorize perhaps the Phasers on board memory could have been bogged down from all the pictures involved in the problem documents and all the size problems associated with large files.
thorntravis
Oct 07, 2009 | Xerox Phaser 8860MFP/D - Multifunction -...
Error code in Phaser 8550 window. ?:07,010.43:1362
The exact explanation per xerox is " The Printhead is stuck in the tilted position, and is not able to tile forward to the print position, due to problems.
This is usually caused by broken printhead restraints, of the machine got shut off in the middle of warming up, and the printhead is stuck to the cap wipe assembly.
Regardless the machines covers will have to be taken off to go any further.
Mar 15, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Phaser 8550 cyan doesn't print
If you go to the Xerox.com site and click support and drivers. enter phaser 8550 and there is a printhead update you need to get, You have to fill out a form.
That may be your problem since there is no fault code.
Apr 13, 2008 | Xerox Phaser 8550DX Laser Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser  8550DX Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
